It is currently 28 Mar 2024, 09:51
Coolhands wrote:Ah I didn't know that. How about my circular saw? (trying to get away from manual work ) It's the corners will be hard work otherwise!
RogerS wrote:I'm afraid not. That's an alligator type.
Sent from my SM-G930F using Tapatalk
RogerS wrote:I really counsel against using a circular saw. It is bulky, awkward and heavy. You are going to be trying to balance it on a piece of timber that may/may not stay clamped in place. As you enter the cut, you're trying to balance the saw, get the aim right etc ad then when you exit the cut repeat it all again. And probably up a ladder to boot.
If you can take back that saw and swap it then it will (a) be much easier and (b) give you a useful tool for later. I never ever use my alligator saw these days.
jules70 wrote:RogerS wrote:I really counsel against using a circular saw. It is bulky, awkward and heavy. You are going to be trying to balance it on a piece of timber that may/may not stay clamped in place. As you enter the cut, you're trying to balance the saw, get the aim right etc ad then when you exit the cut repeat it all again. And probably up a ladder to boot.
Sorry Roger, disagree with you on the circular saw. Yes some can be bulky and heavy, but get yourself one your comfortable with and do it in a couple of passes, jobs a goodun. Done similar before with studwork that's needing adjustment ie ive cocked up !.....
Coolhands wrote:As long as I can bring the epdm down and under the fascia & fix securely will be my only concern (eg keeping it tight all the way along). I can glue to side of fasica board as it comes down, and fix batten on inside edge or underside of fascia board along the length. Just thinking out loud. It's tricky cos I won't easily be able to pull up on inside edge of fascia board as the joists will be there at intervals.
