It is currently 29 Mar 2024, 15:13
+1RogerS wrote:Seriously good progress, Michael. You should be dead chuffed.
Mike G wrote:Well done Michael. As far as I know this is the first workshop to be built from my forum posting on this technique, so I am watching with interest.
Andyp wrote:Could it have been easier to level those lintels by laying them on a bed of mortar?
Malc2098 wrote::text-+1:
As my ole dad used to say, a blind man would pleased to see it!
Well done!
MY63 wrote:.......I bought what I thought was the correct straps for fixing the sole plate to the lintel but they are about 3mm......
Malc2098 wrote:Malc2098 wrote::text-+1:
Well done!
No offence, Michael. I was little when he used to say it and didn't understand till I was building my 'shop and an old mate said the same thing.
I think it can be translated as sometimes, good enough is more than good enough.
Mike G wrote:MY63 wrote:.......I bought what I thought was the correct straps for fixing the sole plate to the lintel but they are about 3mm......
Those are the normal heavy duty tie down straps for houses and so on. They'll be massively too long, and overkill for this little shed. My 30m sq workshop only has the thin universal banding on a roll, which is loads cheaper, and you can just snip it with tin snips, so that's what I suggest is used.
9fingers wrote:RogerS wrote:Seriously good progress, Michael. You should be dead chuffed.
Things will really start moving now as your work goes from a 2D frame on the ground to a 3D structure.
No wonder you were having a bit of trouble shifting those lintels - I'd wrongly assumed you were using the 50 x100mm nom section ones.
Malc2098 wrote:Wow! We have wall to wall sunshine down here!
Mike G wrote:I was in DaveL's workshop this afternoon for an hour or two. After an hour at about 5 degrees, Dave wandered over and lit his woodburner, and we reached the balmy heights of about 6.5 degrees by the time we'd finished.
