It is currently 29 Mar 2024, 10:45
TrimTheKing wrote:It’s just insulated plasterboard. It’s made that way so just use it as it is.
MY63 wrote:Just back from the hospital after having laser treatment to my right eye I hope this means I will be able to get the foundations level now.
MY63 wrote:.......I have two questions can the barrier material go under these concrete blocks?
Where I have removed the grass and a little soil for elsewhere inside the blocks I now have quite a gap.
I happen to have 3 large sheets of polystyrene that would fill the hole nicely it would mean the inside of the blocks would be at the same height as the outside still leaving the planned air gap or does there need to be a large gap below would this sit above or below the barrier material ?
TrimTheKing wrote:.......... If you’re concerned then stick a little more down and whacker it to oblivion.......
Mike G wrote:TrimTheKing wrote:.......... If you’re concerned then stick a little more down and whacker it to oblivion.......
No, I really wouldn't do that. You want some loose stuff on the top for the lintels to settle into. Whacking the lintels once they're in position is all the consolidation that the substrate requires.
