It is currently 20 Aug 2018, 19:22
Shed rebuild
Shed rebuild
Postby Coolhands » 03 Apr 2018, 22:21
In the offing. I have a wooden framed shed / workshop I built 9 years ago, on a concrete base. I made it up as I went along. Roof now leaks and has sagged (rafters too thin which I knew at the time) so blue tarp put over it today. Want to rebuild in summer off 3 courses of bricks.
Coolhands
Re: Shed rebuild
Postby RogerS » 04 Apr 2018, 06:49
Hi Coolhands
Welcome to the forum. There's plenty of information on the forum to help you should you need it.
We love pictures, by the way!
Roger
Re: Shed rebuild
Postby Andyp » 04 Apr 2018, 07:17
As Roger said and a welcome from me too.
Re: Shed rebuild
Postby Mike G » 04 Apr 2018, 07:32
Are the walls sound? It might just be possible to take the roof off, then jack the building up, build a plinth, then put the building back down again (if height isn't an issue).
Re: Shed rebuild
Postby Malc2098 » 04 Apr 2018, 09:56
Welcome from soggy Devon!
Re: Shed rebuild
Postby Coolhands » 04 Apr 2018, 10:27
hmmm I had never considered raising it in that manner. I think it would look odd though as the neighbours have an outhouse a similar height so mine would end up being higher afterwards. The walls are well built but I didn't construct them properly (although it's never been a problem).
eg they are featheredge > uprights > plasterboard with insulation in-between. There is no membrane at all.
I'm so annoyed I never really knew what I was doing as it took a lot of effort to build, and now I might have to start again. The problems start at the bottom - I wanted the base to be insulated to work on motorbikes, so I laid a frame and used insulation. But the frame spacing didn't make sense so the boards dip at some of the edges when I put side stand down etc
see if pic works:
then I built up off the frame outline the perimeter of the slab:
Coolhands
Re: Shed rebuild
Postby Coolhands » 04 Apr 2018, 13:50
I've decided it really does need rebuilding as the roof is pretty rotten (just been up to put a tarpaulin over), and I want a bit on the outside for storage of ladders - roofed but semi-open perhaps.
I also might have an internal wall to have effectively 2 rooms. eg the smaller narrow room would be a clean room maybe used for modelling (RC models) and the larger space for my car tools eg roll cabs etc and space for when I need to get a motorbike in for maintenance.
Coolhands
Re: Shed rebuild
Postby Mike G » 04 Apr 2018, 19:47
Well even if you have to take it down you should be able to re-use much of the timber. In fact, if you can detach the corners (fairly easy if they were screwed), then you might just be able to lay each wall down, cut them 225mm shorter, re-fix or replace the sole plates, and set them aside whilst you build the plinth. Follow the principles outlined in my sticky thread and you won't be having to do this work again, ever.
Re: Shed rebuild
Postby cadman_4 » 05 Apr 2018, 10:26
Welcome to the forum from me too.
I am also working on a motorbike workshop when the weather picks up a bit.
cadman_4
Re: Shed rebuild
Postby TrimTheKing » 05 Apr 2018, 10:43
Welcome aboard Coolhands
Should be a good project and you have some of the internet's foremost UK shed 'experts' to help ;)
Re: Shed rebuild
Postby Jjenks » 06 Apr 2018, 23:03
Welcome, glad you made the move from pistonheads
Jjenks
Re: Shed rebuild
Postby Coolhands » 10 Aug 2018, 12:51
Quick question for anyone that might know. I am replacing the roof (only, for lots of reasons) in the next few days. The span front to back is 4m. I intend to use metric equivalent of 6*2 at 400 centres. a) will that depth be sufficient for that span. I think the existing ones are 4” and more like 600mm centres (they’re a bit random) hence why they have sagged - FYI there is no central support ie no pillar or internal wall, and b) will the existing 10mm OSB boards be sufficient depth so I can reuse them (trying to keep costs down). I know I probably should have used (18mm?) but I didn’t
Thanks
As it was when I built it:
Overall:
Coolhands
Re: Shed rebuild
Postby 9fingers » 10 Aug 2018, 22:00
I've moved this topic into Workshop Builds from the Welcome board simply in the interests of keeping the place tidy.
Re: Shed rebuild
Postby Coolhands » 11 Aug 2018, 08:36
Thanks. I think from reading other topics I need 200mm deep rafters rather than 150mm. Or, could I stick with 150 (as cheaper) and run one long 200mm one from left to right in the middle of the roof to support them? It’s about 4.6m wide. Although I don’t know the price difference, will try and look today.
Edit dimensions are 3.8m deep front to back, 4.6m wide.
Coolhands
Re: Shed rebuild
Postby tabs » 11 Aug 2018, 11:41
I'm building a flat roof as well(probably 10 degree slope) . My span is only 2.4m so not as wide as yours and I may put a green roof on it so it needs to be able to take plenty of weight. I've chatted to the green roof people and been told for my span 6x2 graded C24 timber at 400 centres would be ok. Whether this would do your bigger span I don't know but considering yours isn't going to have the weight on it mine will have it could be ok.
tabs
Re: Shed rebuild
Postby Coolhands » 12 Aug 2018, 11:45
Hi, separate question: I am considering if I did rebuild the shed to put it on 3 courses of bricks as per sticky / mike. But, what if I also want the back wall (only) to be entirely block? Reason being land behind my shed is completely overgrown with brambles etc - I don’t own it and it’s not maintained and they are invasive trying to get under my feather edge.
So can I have one wall only? Struggling to see how it would link with the 3 courses on the side walls. + would it stand on its own and then I build timber frame up to it.
Or should stay wood frame all round but in back wall use OSB instead of feather edge. Thanks for anyone’s thoughts.
Coolhands
Re: Shed rebuild
Postby 9fingers » 12 Aug 2018, 12:04
I think you would need piers every few feet in the block work wall and maybe a one block return at each end/corner for stability.
You can deal with damp-proofing the block wall by synthaprufing the inside surface and adding insulation for comfort. The whole of my workshop is built like this and stays bone dry. I have one 10 metre wall on the boundary that I cannot maintain as my neighbour refuses me access to it and so it is bare, rough pointed, high density concrete blocks left as built.
Return to Workshop Builds
Users browsing this forum: No registered users and 0 guests
