I've brought my Travel Tool Chest & Workbench and Mini Moravian Bench to France for a couple of weeks. The first full day I was thoroughly knackered after 12 hours (including stops) of driving from St Malo down to Monein near Pau. It was also 32°C. With the temperature and the general feeling of exhaustion I didn't fancy doing very much at all. The second day was cooler but we had a bit of an explore of the local area and I never quite got as far as getting going. Today is day three and the bench & chest finally got set up:
Before coming away, I'd had a little session with the bandsaw chopping some bits of wood up. I didn't particularly have a plan for what I was going to make; I just resawed some wood to be about 10 mm thick and some other wood to be about 15 mm or so thick and figured I'd think about it when I got here.
I'm here now, so I guess I need to think about it!
I've started with an off-cut of sycamore, left over from making the bench and which I'd sliced into five pieces, four of them about 10 mm thick and one (not pictured) a lot thinner.
The first job was to sort out the rough-sawn faces, for which I used the bevel-up smoothing plane with a 40° bevel blade (giving a 52° cutting angle):
Another view:
That carrier bag on the right is there so I can chuck (most of) the plane shavings in while I go rather than having to sweep up too much at the end of each day.
With the slices all planed, I laid them out on the chest top and played around with different arrangements until I'd decided what would be the top, bottom and sides:
There was then a bit of cross-cutting...
... and a bit of ripping...
With them all roughly the right size, I could shoot the ends square...
... and I also shot the sides square as it seemed quicker and easier than mounting them upright and planing the edges that way.
That has left me four planks ready to be made into the frame of a box:
The three on the top row will be the top and sides, the one underneath will be the bottom. The box is going to be something along the lines of the drawer box I made when I was away in Brittany last year. The details of the construction are still to be decided though!
I've already made quite a pile of shavings:
Another view:
