I've posted a few things recently in the "Post a photo" thread with my trials and tribulations of trying to get vaguely competent at bowl turning.
I had another go this afternoon and, rather than cluttering up the "Post a photo" thread with lots of photos, I thought I'd start a new one. I started with a couple of the Iroku bowl blanks made from some pieces that @Malc2098 had kindly given me.
I started by turning the outside of both blanks. This is what the first one looked like after bowl gouging...
... and after not too much sanding:
I wasn't completely sold on the outside shape of that first one, so I rounded the second one a lot more. I prefer this shape:
Again, not much sanding was needed:
The inside of the first one went quite smoothly, although I'd like to get better at getting a smoother internal finish off the tool. Admittedly, I didn't try using any scrapers on this one (which might have helped); this is straight off the bowl gouge. This is miles better than any of my previous attempts at getting a smooth finish on the inside of a bowl and, while it still took a fair bit of sanding, it's a step in the right direction.
Sanded:
The second bowl was less successful:
I'd already drilled the centre out (to give a depth mark), so there isn't enough material there for me to cut a new tenon of some sort, so I think that one will have to go in the firewood pile.
After a small amount of cursing, I remounted the first one with the Cole jaws and had a go at an @AndyP style foot:
To keep things nice and simple, I went with a Mike's Magic Mix finish after removing it from the lathe. One coat applied:
That's it for now, but no doubt I'll have a few more goes over the next few weeks. I want to get the practice in before it gets too cold to have the garage door wide open.
Sanded:
