AndyT":22nqogm3 said:Never mind a whole engine, I'd be really pleased with myself if I'd just managed to make that lovely little elbow!
I thought the same thing!
Cabinetman":2fkh70fg said:Still don’t really know what it’s all about, but it really looks well made and very smart indeed.
SamQ aka Ah! Q!":1p7nbkir said:Looking at the video, a lot of these type of stand-alone workhorses were referred to as "Lister engines" in the farming communities where I spent my formative years. Whether or not Lister actually produced them!.
And there's me chuffed at just fitting a replacement bearing sleeve in tractor tyre inflator pump crank end for a farmer friend on Friday.
Great to see some of these parts assembled. i’ve struggled to follow and understand some of the individual bits as you have been making them. Beginning to make sense to me now.
Well done on cutting the test tube!! We cut tubing nearly every day. We simply notched with a few file strokes, then snapped it. A quick polish in a Bunsen flame sorted the edges.
Test tubes are of different glass, as they have to withstand thermal shock of quite a magnitude. Their chemical constituents are different to tubing. Never heard of someone cutting them before.
What's the lathe & what's the part?Work has come to a halt at the moment my lathe decided to strip a gear so now having to wait 12 weeks for replacement parts (OK it was my fault it happened) I am however trying to assemble some of the parts which can be a little fiddly due to the size and my large fingers.
I will post when things progress
Thank you for the offer. But for the time being, I can disconnect the travel and use the lathe by manually traversing the bed. I also have some milling to do as well as kept busy with other chores around the garden and house.What's the lathe & what's the part?
The only reason I ask is that I had it in mind that yours is one of the Sieg Chinese lathes. I've got an old Sieg SC2 (the shorter bed version of the SC3) in storage. One day I'll probably do something with it, but if it's the same as yours and you want to borrow a part while you wait for your new one, I'm quite happy to stick it in the post when I get back from Brittany.
For interest, the lathe is a Warco WM280V
Sorry I must have missed your post, securing it is not a problem either way. Yes I agree it is better access with them facing out.As always I am impressed. Foot out may be handy if you wanted to fasten it down?
