Windows
Why aren’t hydraulic tools more popular for woodworking?
Are fluid tools more complex? (I’m not saying they aren’t. I literally don’t know). The kind of thing I’m wondering is why does everyone using a router have to carry & push a motor around that can’t be shared between tools? Spinning a bit at the business end using a fluid seems simple (to me who has never given it any thought and is not trained in mechanical engineering. LOL) and much lighter and more manoeuvrable for the operator.
Dentists (often? sometimes? rarely?) use air driven drills, for example.
Indeed just batteries to be replaced after how many years/charging cycles? The cynic in me sees rechargeable anything as an advancement in the built in obsolescence that manufactures have been practicing for years......and battery tools are changing the game once again.
No leads or hoses to get tangled.
Duncan
In fairly heavy trade use, the answer (for professional level batteries) is something like 4 to 6 years at 3 to 6 charges a week. The thing is, regularly used trade cordless tools rarely survive much longer, given the way they are so often abused. And the replacement model after 5 or 6 years is often lighter, more powerful, has better ergonomics, etc. That said, I've now had 9-1/2 years out of my Makita (brushless) SDS drill, albeit with a couple of minor repairs and a new body shell after I cracked the last one by dropping it off a cherry picker. I don't know how much longer my current 18 volt Makita LXT batteries will be available, but they've been around since about 2005 or 2006 in the UK and Makita are still introducing new tools for the range, so hopefully I'll be able to get batteries for a few years yet. Against that I have to admit that some of my regularly used corded tools are 30+ years old (generally the ones without any electronic doohickeys, though)Indeed just batteries to be replaced after how many years/charging cycles? The cynic in me sees rechargeable anything as an advancement in the built obsolescence that manufactures have been practicing for years.
Yes, but will it drill multiple large diameter holes in heavy masonry - say 24 no x 16mm diameter holes for resin anchors into Accrington blues (dense engineer's brick)? Not a chance! My 1981 Bosch SDS could still do that until just before I disposed of it at age 20, my 9-1/2 yo Makita still does that. Reason for Bosch disposal: unable to obtain a component required for a repair (a capacitor). The two limiting factors are probably long term battery availability and parts availability - both substantially better on trade models. Purely from the point of view of a regular tool user in trade, though, modern power tools are just so much better than what we had in the 1970s, 80s, etc, For that I accept that they aren't going to last foreverHad cause to use my father’s old Bridges electric drill a few weeks back, must be at least 60:years old. No hammer function but still capable of drilling holes in brick work. I wonder how many cordless drills will last that long,
One of the problems I sometimes have is that there isn't always corded power available where I need to work - bear in mind that we are legally required to have 110 volt on site in the UK, and that there is a finite distance you can run such cables before voltage drop bfecomes an issue. In my case a mixture of hand and cordless tools has become a necessity in order to complete work to schedule, especially as there is always a goodly amount of drilling and screwdriving to do, for which cordless knocks corded i to a cocked hat. Ten to fifteen years ago I'd have agreed with you that many of the power tools I need simply didn't exist in cordless. However, over that period there has been a revolution in cordless technology with the arrival of brushless motors, 36, 40 and 54 volt battery systems coming of age and something of an explosion in the range of tools available. These days the main corded tools I need are probably my Milwaukee recip saw and a 230mm Hilti portable rip saw. For the rest cordless often suffices. And you learn to deal with battery life by ensuring you are carrying enough batteries of sufficient capacity. BTW I mainly undertake heritage work, and it isn't all redone using the original methodsIf I had to cut short the lifespan of my tools because of limited battery life or planned obsolesense it would increase my costs to such an extent that my work would become unaffordable. Some of my larger on-site power tools and machines don't even exist in battery powered version so I need power cords onsite anyway.
It's actually very far from that. Our current core team is 4 carpenters (although the full.site team contains anything from a dozen ttsdesmem up to 100+ on the last phase) with other bodies pulled in as required. We utilise pre-machined components where it is more efficient (i.e. cheaper), and the same is true for some of the repair work which is done by the workshop rather than on site, because it's all about the bottom line, but we still do a heck of a lot of standard and traditional carpentry - anything and everything in the course of a project from shuttering to roofing (standard pre-manufactured truss roofs up to things like traditional m&t iòking post truss roofs, etc) or floor joisting/studwork to (re)installing oak panelling, and so forth.0 I need to be able to do modern carpentry, such as metal-framed plasterboard ceilings and suspended ceilings as well as to be able to recut and repair the aforementioned king post trusses, box guttering, skirting grounds and even lath work (for lath and plaster walls). The (one) thing we don't do is log framed buildings - it's not really part of the tradition here, at least in England. But if somebody came up with a 300 year old one which needed restoration...I see. You work as part of a large crew with a logistic backup and with premachined parts arriving to the site. Where every man is rather specialized.
