Geberit Type 240 and Type 340 mechanisms
Just staring blankly at the 'instructions'. I use the term loosely as they are only pictures but there's a load of settings to be worked out. When did toilets get so up themselves with complexity.
Has anyone fitted one, please, and can enlighten me ?
Doh....just asked ChatGPT. Damn good starting point but all help still very welcome
I know what you mean, Roger. I've started to make my kitchen drawers using Emuca kits. Decent quality, but ZERO INSTRUCTIONS. Nada. Zilch.
There are some animated videos online which show you how they are assembled, but not HOWTO MEASURE OUT for that assembly. Plus I got two pieces "clicked" together and it took me nearly an hour to find out how to Unclick them. Very easy once you know how, but impossible until that point.
And you think today's crossword was hard.
Can’t help Roger with that particular make. I did get so fed up with the plastic gubbins on a similar device getting furred up with the hard water we have here that I replaced it with an old fashioned ball cock.
Roger... I did a Google search and got some 'guides' but it ended with this (before I copy/paste the rest):
"For detailed manufacturer installation notes and documentation, consult the Geberit Installation Notes. For step-by-step guidance on changing out these specific parts, refer to the National Shower Spares Installation Guide.
Could you tell me if this is for an exposed (ceramic) cistern or a concealed (in-wall) cistern? This will help determine how you need to adjust and cut the flush rods for the push button.
I'll copy/paste the 'guides' in the next comment
Trying to copy/paste pastes as gibberish... probably best to search for "Geberit Type 240 and Type 340 valves" to get the listed information/bold text...
Apologies Roger... you may already have seen this - and other - vids on YouTube but wondered if this would help? Funnily enough this video is on the (above) link to the National Shower Spares Installation Guide...
Thanks Frank but that link quickly goes back to the standard (and frankly useless) video.
I think Geberit need to rebrand as Gibberish’s
Always a good idea to keep things simple, a ball cock is basic and been around for years whilst all these new fangled toilets with fancy operating ideas can become very expensive to fix. Also whilst we are here has anyone questioned why some toilets are square, you get a lot of rounded rears but as yet never seen a square one !
Also if fitting a close coupled cistern then make sure you use a flush syphon that can be partially removed to fix without having to remove the cistern to get at the retaining nut, saves a lot of work.
Best out there is
Best out there is
The Geberit can also be removed from the top of the cistern without having to separate cistern from WC
Completely agree regarding syphons.
Ballcocks? I used Torbeck valves for years, and they've been excellent - quiet compact and reliable. The problem is I think that the British company that last owned the brand was bought out by an American monopoly (name escapes me), and they stopped production (I think). The American designs, which are horrid, are now flooding the British market, including many of the sheds and big online retailers.
What exactly are you struggling with Roger, there’s a setting for height & desired flush volume, they are both pretty basic.
As for ballvalves these days I tend to stick with the brass shanked Fluidmaster fill valve, I dislike any plastic threaded ball valve for obvious reasons & I’ve never had a problem with the Fluidmaster
Hi Doug...thank you for the offer but no longer struggling as the WC front-to-back length too large for the space and so it's been sold on !
