Hardest part of hand planing for me is planing edge square to face. Tips?
SteveMP
Steve
San Diego
I can get an edge mostly straight longways. But i seem to almost always put a slight bevel one direction. So then i get out my square and check along the length, then mark high spots with pencil and try to take off high spot, then either make a “crown” or inadvertently plane the opposite bevel and have to repeat a few times. Any solid tips?
For planing the edge, at school Woodwork lessons, 60+ years ago, I was taught not to hold the plane front knob, but to hold under the sole with the fore finger and the top of the sole with the thumb just in front of the mouth near the knob. The forefinger then 'feels' the workpiece as you push the plane along, and your wrist controls the the angle the plane is relative to the work edge, so with practice prevents the bevel from occurring.
Do you have a camber on the blade (e.g. made by rubbing on the sharpening stone with extra pressure on each side in turn)? With a cambered blade, you can move the plane side to side rather than trying to tilt it. If you hold the plane body rather than front knob (as Malc described), your fingers act as a fence and keep the same part of the blade on the wood. Run it over to the right and it'll take more off on the right as the cambered blade will taper off to the left. Vice versa for the left or run it in the centre to maintain a square edge.
I have seen Paul Sellers do this and tried it with no improvement. If I am understanding you correctly, with practice my fingers will learn to feel square between the plane sole and face of board? Maybe I just need to build the muscle memory?
My 5 is cambered but my 4 is flat. All my Japanese planes are flat. I was trying a trick where Paul Sellers showed running the plane all the way to the edge on the low side so that the metal part of the sole on the side of the blade won't cut, thus only cutting the high side, but thats when I get sort of a crown on the board.
I don't run it all the way to the side: the blade sits on the workpiece, not the metal side of the sole. The cambered blade means it doesn't cut at the extreme: you can think of it a bit like a V-shaped blade so if you slide the plane to the left, you're cutting on the right-hand side of the V and taking more off on the left than on the right. The last pass (or several passes) are down the centre & that's where the fact it's more U-shaped than V-shaped helps!
I do not do enough edge planing to do this by feel. I found an uncambered iron and a fence clamped to the plane an acceptable solution. Something like this (not my image)View attachment 58262
Interesting, I had looked at the Veritas jointing fence or whatever its called, but this looks like a much cheaper solution. Never thought to clamp something to the side.
You've been told the basic technique by enough people above for me not to repeat that. The thing I would emphasise, though, is to slow down. I mean, really slow. I've just been doing it for an hour or so and if anyone were watching they'd think I was being unnecessarily pedestrian. Well, so bit it. It's all about control, not speed. Oh, and put a square on the edge every 2 or 3 passes of the plane.
Interesting. I watched the Matt Estlea video and his camber is much milder than what I was thinking. My 5 has a Chris Schwarz style camber, like this: https://blog.lostartpress.com/2019/11/25/grind-the-iron-fit-the-chipbreaker-part-3/
works well for hogging off a lot of material but probably too much for an edge.
I never purchased "Sharpen This", but looks like Chris has a similar way as Matt here for smoothing planes: https://blog.lostartpress.com/2022/09/27/how-to-hone-slightly-curved-blades/
Will have to try this on my 4.
Check your planes for square, first. Many of them aren't!
I would add to all the comments that your bench top should be dead flat in both planes; check with a spirit level and adjust accordingly with packers under the bench legs. The bench top is your main reference and if that's level and true it makes it easier to hand plane an edge, knowing that the broad side will be a true vertical - Rob
Yeah, that's way more than I have on my planes. If I took a photo you wouldn't be able to tell there's a camber, it's just what comes from maybe five or ten strokes on each side on the last (finest grit) sharpening stone. It's enough that you can set the plane to take a very fine cut in the middle but nothing on the edges (and hence know it's aligned right) but when you extend the blade to take a deeper cut it starts cutting all or most of the way across.
I learned that the hard way using old vintage Stanley planes for my shooting board. Took me a while to figure out why it wasn't working.
When I first heard of this camber I was wondering why it didn't just plow a trough into the wood until I saw this. Its a good visual and a nice calculator to figure out the maths based on bed angle:
Yes, plus everything else on this thread. :)
Thanks. I’d been using power tools for decades. I got dependent on setting up my table saw and not thinking twice in having to square up sides etc. I am fairly new to hand tools so its like learning everything from scratch.
This is what I do, too. In fact, I was doing this 5 minutes ago.
A straight blade and with a fence won’t help much. When planing you will weight one side of the plane more than the other. In other words the push effort will be biased to one side. This causes a slight chamfer to be created in the edge your planing. The solution when trying to use a straight blade is to slightly angle the blade which is a whole waste of time and effort.
You need a slightly curved blade to plane and particularly to edge. By using your fingers as a fence you can offset the blade on the board and therefore compensate by moving the plane slightly away from the biased edge. In effect you create a slight chamfer in the blade setting by doing so. Very quickly by making a pass and measuring you will get a feel how to naturally bias your fingers on the plane body. A slight concave cut on both pieces also helps to make a better looking joint. The outside edges are crushed slightly when it’s glued up making a neater joint that reduces the amount it might open as the moisture content if the stuff changes.
When jointing start out by making sure the piece is humped or convex in the middle along its length. If it’s concave it’s very difficult when learning to achieve a good result. Starting a plane consistently at an edge takes time to learn. A hump means you start planing in the centre and work your way to the edges. A beginner almost always planes stuff hollow or concave in the centre, so staring with a hump plays to a weakness.
if you are still having trouble try buying a no7 or no8, for me it transformed my hand planing, just keep practising jointing until you get it right with no gaps, I had the same problem of not quite getting it square, but with enough serious practise you'll get it spot on, it takes a lot of patience and constant checking but you'll get there, you want an airtight joint and it all starts with proper face/edge marking and removing any twist from the face.
@thetyreman makes a great point. A longer plane does make it easier to flatten along the stuff’s length. For me a number 8 or 7 was too long and large for most stuff, although they come into their own if you straightening and edging very long stuff. I find a no6 is a perfect compromise for most things. I have large hands and stand over 6’ and the longer planes are still a bit cumbersome.
I have to say, I only hand joint these days when it’s too thin to go though my thicknesser successfully.
@SteveMP ... great topic to make a posting on. Sadly I can't offer any advice as it's so long ago I used mine (I posted about having to clean mine up 😕) BUT I'm finding the information and guidance posted here very interesting... so a big thanks from me. I rarely got it right when I did need to plane edges so now have a better understanding.
I have used a shooting setup to plane an edge with my No 6 occasionally.
Obviously you are restricted to length in this setup up, but if your plane side is 90 degrees to the sole and you have a flat board to shoot off, I use MDF, and the bench is flat, then with a fine cut I have found that it works for me.
A cambered iron is the only way. A perfectly straight edge can only deliver a flat surface with perfect control, more likely a convex one. Cambered iron makes a flat surface possible, even in the presence of slight deviation of plane angle / pressure.
Yeah gonna try and put the camber on my #4 like Dr Al’s video from Matt Estlea and do some practice runs
You will effectively "disable" your smoother, if you emulate folks who intentionally won't show you how the tool
should work!.
Note the straight shaving, with no sign of any curling.
This is because the cap iron is actually working.
A noticeable camber at arms reach (for someone with very good eyesight) will surely be far, far too much...
which thereafter with subsequent sharpenings, would take quite a long while until the cap iron could get close enough again to work correctly,
as the corners of the cap iron would stick out otherwise.
If looking for videos, my advice is to notice the wheat from the chaff regarding the smoothing plane.
A smoother should be taking shavings which wont tear out the grain.
Don't see that, then their having you on, and they don't intend for you to progress.
A simple thing to note, proof that you won't see many demonstrate, as there's money to be made in that game.
All the best
I use the Veritas jig for that with the 'barrel' shaped roller, applying an even number of strokes each side using forefingers to apply pressure. The camber is barely perceptible but it's there - Rob
IIRC ... School 'O'-level woodwork class said the #4 smoother was for smoothing glued up joints, with a light cut, and a straight iron with slightly rounded corners to reduce tram lines. A #5 Jack should have a cambered iron. I don't remember what they said about larger sizes.
Did we go to the same school? :LOL:
Hello again, regarding rounding of the corners of a plane iron...
There's no mention of suggestions given, having the huge caveat for those who might not be aware!
It's fairly obvious with the videos suggested earlier on in this thread, that sure seems like either a lack of familiarisation with the use of a smoothing plane, or the assumption that everyone has a load of no.4 planes and nothing else.
Should one seeking advice, have a panel or try plane in their possesion, advice of rounding corners on a smoothing plane doesn't apply here,
as rounded corners what would be enough, to not create plane tracks, suggests the wrong tool for the job.
Such practice could very well disable the function of the cap iron, for a long time.
I don't claim to be any expert, as that would suggest extensive testing regarding cap iron steepness, and distance set from the edge.
As mentioned before, I can merely give suggestions regarding the distance away from the edge,
for panel/try and smoothing planes, when the cap iron is honed at 50 degrees, which isn't very steep, but the bare minimum.
It's the bare minimum for a smoothing plane, as honing the cap iron at anything less than this,
wouldn't allow any profiling of the cutting iron, due to the cap iron needing to be even closer to the edge.
In other words, the shallower the cap iron is honed, the closer it needs to be, to function as intended.
For a smoothing plane, a cap iron honed at 50 degees, will require the distance from the edge, to be no further away than 1/64".
Basically, my advice is to be careful with overzealous profiles on smoothing planes, and to start with a straight profiled cutting iron,
and slide the cap iron with accordance to this minimum steepness.
You might indeed find, that there actually is a profile of the cutting iron after all, and you're not able to get it close enough,
to work, i.e. to straighten out the shaving.
Which leaves only one option thereafter, (if adamant to retain a certain amount of camber/rounding of the corners.)
That will be to hone the cap iron steeper than 50 degrees.
Not much info out there regarding such, but should that be of interest, your best bet might be finding Derek's postings.
Sorry for the long winded post, just trying to ensure the potential for learning the basics isn't thwarted.
All the best
Tom
Try planing the edge with a block plane. The aim here is to get a feel of what square is. There is more feedback when you use a bevel up plane where the centre of gravity is low. Then try a low angle/bevel up jack plane or jointer.
Before planing, scribble with a pencil along the length of the edge. Determine how the edge lies in regard to what is square and what is not. Try to hold this as you plane, creating a reference flat. You will know you have a continuous square edge once the shavings are full. Then create a slight hollow at centre of the board, before planing through.
Thanks, will try a block plane. I don’t have any bevel up planes larger than a 60 1/2. I did almost buy a Stanley 95 once but figured its probably just a good skill to build
This might be of interest. I have found it to be generally beneficial.
When I have an edge where one side is much higher than the other, as measured with the square from the flat face, I put the plane on the high side, estimate horizontal by feel and plane until I take a full width shaving. It is remarkable how few passes (usually 3-4) need to be made for the resultant flat to be wide enough under the plane for the plane to register on it.
Once the full width shaving is produced, I check with the square to see how close to square it is. The result is always an improvement and is often only a whisker away from square. I then repeat the process with thinner shavings and obviously very few passes are needed to get the next full width shaving. If it is still a bit off, I have the option of skewing the blade or planing a third, two thirds and then full width.
There is obviously the more traditional alternative of using a cambered blade to get towards flat. The reason I like the above method is that I like building up the muscle memory for a feeling for horizontal.
This is the thing that often gets overlooked. If the face is twisted, you’ll get the impression that your edge is leaning one way in one place and the other way further along. Take some extra time to check that the face really is flat before moving on to the edge otherwise it will never be right. Winding sticks are essential to do this properly.
When I attended David Charlesworth's week-long Tool Tuning course, the final exam was to turn an irregularly shaped slab of tortured walnut into a 6 x 5 x 0.75 inch board. I don't know how or when he prepared the block, but M.C. Escher could not have done better. The intent was to use everything he taught me during the week, and I am happy to say I succeeded, even though it took most of the day to sneak up on the dimensions.
I taught a beginning woodworking class once and started with stock prep with hand tools just like this. I thought maybe the students would find it boring but it was just the opposite. Most had never used a hand plane or square before and it was a revelation that they could make a board flat by hand.
