Windows
Any fans of the linseed oil paint? I remember Roger was pro then anti. Anyone else got experience of it? I’m thinking of getting some samples from Brouns for exterior woodwork.
You just wait and seeAny fans of the linseed oil paint? I remember Roger was pro then anti. Anyone else got experience of it? I’m thinking of getting some samples from Brouns for exterior woodwork.
I’m hoping it’s not going to go mouldy.You just wait and see![]()
No it isn't the moisture. Linseed oil paint is vile.The third coat is not yet dry after 24 hours. We had some moisture overnight and overcast this morning so presumably that is the cause. It looks ok except for the fly caught in it.
I mean that my theory is that the clouds & drizzle dropped the UV & temp slightly compared to the previous 2 days so slowed curing (not that the moisture itself has much effect). But maybe it’s just cause it’s the third coat?No it isn't the moisture. Linseed oil paint is vile.
Spot on. One of the reasons why I'll never use it again. You've already found the second reason !Tell me more about how it’s vile. I love a good horror story. It’s definitely different to other paint I’ve used. Do I recall correctly that you used Allback paint without adding zinc oxide and it went mouldy?
The slow drying? What’s the third reason? What have you used for exteriors since the linseed incident?Spot on. One of the reasons why I'll never use it again. You've already found the second reason !
Little GreeneThe slow drying? What’s the third reason? What have you used for exteriors since the linseed incident?
Viking has zinc oxide added to stop mould.I used Viking linseed oil paint (white) on the rafter end grain of my Japanese shed. I applied the paint in fall before the rains came. One thinned coat to start then a top coat. Each dried in a few days. After two long wet Oregon winters it still looks new. No mould at all.
It's bad for the environmentIs zinc oxide particularly bad? The safety section of the Wikipedia page is not ringing alarm bells.
Zinc oxide - Wikipedia
en.m.wikipedia.org
I’m still in the experimental stage with the linseed paint, but looks like I’m going to do at least three full windows this summer if nothing crops up to put me off.
The third coat of the paint was fully touch dry within 48 hours, with the first two coats each touch dry within 24 hours so not worried about drying time.
