Has anyone tried out this little blighter? I could find the BrIdge City version on Banggood for £98 or on their own EU site at €69.
This little version is much cheaper.
I also grabbed the setup blocks on a special offer.
I am using them to make up my binding stock for my current ukulele heirlooms project. The rebates for the binding are cut using rebate bearing cutters, so the dimensions of the bindings are dependent on the the combination of bearing and cutter. As I am working to a notional thickness of 1.5mm, I find my drum sander isn't always consistent with such small thicknesses. So I thought I'd give this combination a try.
I'm getting to like it.
Obviously I had to give the blade a good going over when it first arrived, but it seems to hold its edge well enough on the Paduak I'm using.
I will glue the bindings in to their rebates slightly, about 0.5mm, over size, and scraped down to the instrument rim.
The combination is accurate enough for me. I'll take 0.1mm out on the planing.
And on my setting up the plane with the blocks.
The cheapest Padauk binding I can find in the UK is about £2 per strip, some is even advertised at £5 per strip. An instrument needs four strips. So, you can see why I now choose to make all my own timber components for my instruments (apart from kerfed linings), which I think makes them quite special.
