AJB Temple
- Joined
- Apr 15, 2019
- Messages
- 7,410
- Reaction score
- 947
Just had a fair old belt from the mains, which woke me up somewhat.
Needed to replace the switch on a lighting circuit. Two gang two way. Plastic switches previously and the previous person just snipped off the CPC (earth) which was unhelpful rather than taking ten seconds to connect it to a terminal block. I tested the live wires and neutrals with a Megger, then switched of the circuit at the consumer unit RCCB and tested again for dead. Twas dead.
Put my finger in plastic socket to pull the earth out so I can use it and "BANG" I get an electric shock. Rubber soled shoes on dry stone floor and only one hand in contact, but this was my first electrical shock in 35 years as I am generally super careful and do the prove/test/prove again routine always with a meter of Megger probe. So I was VERY surprised. I was also alone.
In this case I had not been able to get the probe to the "earth" wires and assumed that they were genuine CPC. In fact one of them was live and connected at one end to the socket circuit in the same room (as I now have proved) and someone had used a yellow cable and re-sleeved the last few inches as green and yellow. I can't imagine why someone would put a stray single wire down to a socket, sleeve it as CPC then bury it in a wall void.
So that is the lesson for today - never assume. Still buzzing......
