Another week is almost over and despite the lovely sunshine I have managed to catch a few hours in the workshop. I'd better post some more photos before I forget what they are of.
I left you with some attempted repairs to flaws on the insides of the legs. I think they will be ok, but I seem to have omitted to take detailed 'after' photos. If anything looks too bad, I can cut some fresh legs and start over. Here's the story so far, with the best sides outwards.
I needed to decide how much the top would overhang the frame, in order to cut the rails to length. So here are the legs, balanced in position.
I decided that wasn't right and moved the legs further out.
That took quite a long time, as it included measuring other tables and looking at pictures. If I was making a video of this build, everyone would be pressing fast forward by now; but it all takes time, and goes some way to explain my glacial rate of progress. But I'm happy with that. I much prefer having a project on the go to just rushing ahead and then wondering what to do next.
While looking at the underside of the table top, I noticed this bit of damage on the edge which needed to be planed off.
Looking at the timestamps, there seems to be nearly an hour between those photos! Maybe I went and made something else in the interval, or maybe I just moved stuff around, sharpened the tools and thought a bit.
(One point of showing the top being supported is to mention how useful it is to have an adjustable something to put in the opposite end of the vice when gripping a big piece on one side. I use a bit of plywood with a stack of bits of thick card, which adjusts nicely, but there is obviously plenty of scope for cleverer solutions. )
Next, I spent some time tidying up the underneath, getting it flat enough where the rails will go.
There's a lot of really enjoyable planing in this project, but I guess one photo looks much the same as another.
On the top side, I also did some scraping. It's nice to go from this, where there are plenty of visible flaws
to this, which is a bit better, and nearly good enough:
One thing worth mentioning - if only to agree with
@TomTrees, who I know is strongly in favour of it - is to use low angle lighting to examine a surface. I turned off the usual bright overhead lights and used one old anglepoise to show this ghastly bit:
which got tamed so it looked like this instead:
I had decided to give the top a simple chamfer, so it matches the other small tables. This was an excuse to play with my favourite block plane, which you will all have seen before,
but also to use this little Mujingfang plane, which is also excellent on end grain. The big difference with this one is that the iron is set much further back in the body, so there is a longer toe in front of the cutting edge. This makes everything more stable.
Marking out the rails and cutting them to size kept me happily occupied for an hour or more. The old brown stain came off very easily, revealing the quality of this old oak:
so I soon had a kit of parts ready.
By this stage, I was being very careful to keep checking that I had all the parts the right way round, to make sure the best surfaces are in the right places and to avoid silly mistakes. I'm not experienced enough to have a deeply learned system of marking the parts, so I borrowed Rob
@Woodbloke's idea of using coloured stickers. After marking mortice positions and then gauging the tenons, I ended up with this rather untidy state of affairs:
which all makes sense to me, provided I don't leave it too long, but there will probably be a week or so without any progress to report. Not to worry! The customer is patient enough.
