OOPs and some.
Lons
Northumberland
Last week I got a frantic call to help out some longstanding friends in an emergency so my wife and I were there in minutes to this horrific scene and both of them were in a serious state of shock though unhurt physically. My wife being an ex nurse sorted that side as there were no injuries while I spent an hour and a half sorting out both car and house insurance for him as well as emergency temporary repairs as the lintels were no longer supported. There were blocks falling as we walked up the driveway.
What surprised me was that the car insurance company said it‘s an increasingly common accident and he was lucky it’s a hybrid rather than an EV which would have most likely required a new battery pack as the car “climbed” over the concrete blocks. The guys who came out that evening to make safe and secure the premises said this was the third they had attended in the last 6 weeks :rolleyes: That wasn't locally as they cover a wide area.
This photo taken half an hour or so after the accident shows only part of the damage which is extensive. I’ve blanked out his number plate so it can’t be traced. The roof looks as if it's sagged in the middle but that's just a quirk of the camera and it's all supported now by acro props.
His wife luckily was standing watching him put the car away so pulled him out. How she managed is beyond me as she’s 6 stone soaking wet, adrenalin I guess. I took a risk and managed to retrieve his ‘phone and keys from the car but thinking back I shouldn have done that.
The car is a 1 week old, a nearly £60k Merc. with less than 100 miles on the clock. He'd just traded in his previous smaller GLA so this being longer was a tight fit for length in the garage and he was inching forward when his foot slipped and wallop, straight through an internal concrete block dividing wall, though the utility sink and washing maching and demolished the external cavity wall as you can see. Burst a water pipe which was too dangerous for me to get at and was a full mains pressure fountain luckily directed into the garden so I had to turn off the main supply. I found out later it had fractured the oil pipe supply to the boiler as well though that didn't leak too much.
The car has a smashed windsreen and a lot of superficial damage but nothing major and the airbags didn’t fire. ATM he’s talking about going back to a smaller car or giving up and they’ve already given him a trade in value substantially less than he paid so I’ve got first refusal if he does. It will be repaired by the MB main dealer so I’d have no issues with that
I’d have to get that past the wife which could be a major hurdle though. :unsure: :)
I retired from full time work as a collision investigator/road safety engineer ten years ago. But even back then analysis of crash data showed a correlation between the older driver and cars with automatic gearboxes while not in collision with any other vehicles, but frequently against a wall.
I'm going to stay with a manual gearbox for as long as I can.
I once (long ago) had a Vauxhall Astra (a mistake). I found quite suddenly that the ignition lights were staying on when the ignition switch was turned fully off, and even with the key removed. Being a bit strapped for cash at the time, I investigated it myself. Pulling the connector off the back of the switch, all the lights went out. Probably the switch then. Dismantled it - the design is a backplate with raised contacts on it, and a triangular plate which rotates over them as the key is turned. Raised pips at each corner connect the contacts below as the plate rotates. When they wear down, the whole plate sits across all the connections giving the vehicle a life of its own independent of the presence of a key. I fixed it by soldering on some new pieces of contact strip from my junk box over where the worn ones once were. All good.
One of my Dad's colleagues had the more advanced form of this problem, and the car tried to start itself in gear in the garage.
I had a number of other interesting electrical issues with that car. Including the time smoke erupted from the dash. It carried on going. I rolled the window down to clear the smoke. It still carried on going. Never found out what let go.
My take away; buy a manual car. Never again a Vauxhall. Leave in neutral unless on a steep hill.
That was quite a slip of the foot - wrong pedal ? A good outcome that nobody was hurt though.
An older chap down the road from us did a similar thing had a new automatic car delivered and the next morning he reversed at speed across the road in to a drive way demolishing a fence and ripping a gas pipe off the wall.
I am glad no one was hurt.
OOh!
I'd want to see any logs the car's computer generates. Casting no aspersions on Mercedes, it was probably human error, but not necessarily. There is a lot of sloppy firmware out there, and I'd want to know if it recorded a sudden change in the throttle position, or not.
Long ago I stopped trying to get manual cars from hire companies in the USA, but automatics still make me very nervous. I'm also, probably, the only person in the whole of North America that actually uses the parking brake...
Didn't Vauxhalls have a problem with the blower speed control catching fire in the dash?
Yes - the ZaFIR(E)a ironically enough
If it were me Id recompose and then refer myself to the DVSA for a retest rather than be pressured into retiring
An ICE with manual transmission would possibly have stalled instead.
Back when ram- raiding was de rigueur the supermarkets installed pillars around the entrances but Tescos in Ledbury was ahead of the curve and had them fitted after an elderly driver drove down the car park and instead of braking at the junction in front of the building and turning left, she hit the accelerator and went through the shop doorway.Miraculously no injuries or damage.
it's the same car as mine Malcolm except that mine is older of course and this is a hybrid. I've never had a single glitch with the auto box which I think is excellent and I've had several auto Audis before that. It's AWD which didn't help I think as if FWD it wouldn't have reached the back wall possibly as the car scrabbled for grip. The accelleration on mine is qick, his with battery boost is quicker and that's part of the issue these days especially with EVs that have the 0-60 of a supercar not too long ago. Those in the hands of the wrong people, kids especially is a recipe for disaster. All EVs are auto so the days of manual cars are disappearing.
The MB dealer has already said it will investigate as well as repair though they'll find nothing of course and my mate says without doubt it was his fault. Personally I think the accellerator and brake pedals are sometimes too close together in some autos.
Anyway I personally wouldn't go back to manual these days, I can use the paddles if I really wanted to but don't and the option of flicking into sport for pulling out of junctions quickly and safely is all I use. My wife wouldn't change her auto Mini back to manual either.
We don't however park our cars in a garage, that space is far too valuable to waste on a car. :ROFLMAO:
Wow, that's awful.
Good luck with 'negotiations' and the missus. Glad nobody was hurt - Rob
Probably never happen Rob but I did mention it in passing. No reply just the usual rolled eyes and I'm already in the bad books for getting a camera. Women have no reasonable priorities. 😉
The couple are fine, I've been to see them several times since the accident. Apparently he's never been involved in an accident of any kind or made a claim previously and it was a bad day as he'd just got a letter saying he'd been clocked at 33 in a 30mph zone on his way home after collecting the new car so has to go on an awareness course.
I've had automatics for my last 3 cars and 20 years and never had an issue. I'm not saying there aren't issues but I don't believe they're widespread enough to feel that they're a complete no go.
My bigger issue with modern cars is not the automatic transmissions and more the fact that the entire car is run by computers and sensors, and when they go wrong you need to be an electrical diagnostic wizard as well as a mechanic to even work out what the issue is.
Ouch! Poor guys, glad to hear nothing more than pride damaged and everyone healthy. Must have been scary for them.
That's the first time I've seen the effects of shock Mark and it's scary. He was laid flat out shaking and confused and his wife wasn't much better. A neighbour came in with tea and we put enough sugar in it to make a spoon stand up, his face a picture 'cos he doesn't take sugar.:ROFLMAO: Didn't want a doc or hospital so we were there for several hours to be certain they were OK, I rang later and called round the next morning.
Sorting the insurances was a nightmare as I'm not the insured and he was too shaken to do it but got there in the end.
I think that was probably it; the blower "speed control" is usually a group of resistors switched into various series/parallel configurations - I would guess one burned out, so no all the blower speeds worked, at least at the speed it should, but I never noticed. How hard is PWM really ? A 555 would do an adequate job.
I used to fix tv in the good old days they where like to much voltage? bung it through a big resistor and burn it off.
Good to hear they're both OK, albeit a bit shocked. At the end of the jour, it's only 'stuff' that got damaged and that's all replaceable; a 10% margin on yer speed is all it takes to get a ticket and if I'm out with SWIMBO and I remotely stray over or anywhere near the limit I get the 'sideways look' followed by a 'cautionary word' in my left ear 'ole, so now when I'm out on my own in the motor I stick strictly to the speed limit - Rob
After picking up 9 points in the space of two weeks (on a previously clean for 20 years license), on the same camera on the M62 variable speed limit stretch, I now drive like an octogenarian granny!! Six of the points expired early July with the other three expiring early November, then obviously I need to wait another 12 months on each for them to officially come off my license...
Jeez, many positives to be taken when he has time to reflect. Imagine that happening in a car park somewhere with people around. A less well built and robust car could have been worse too. Can understand the shock he must have felt.
I'm still struggling to get used to button start. Muscle memory after 6 months stills try to turn off a non existent key. Never considered an automatic, more expensive to buy, less economical to run, and heavier on the brakes are my non scientific reasons.
Never owned an automatic and have no intention of ever doing so, but driving one on a 'fly drive' tour of the Canadian Rockies a couple of years ago isn't an experience I'd care to repeat, fabulous as the scenery was - Rob
Have had turbine coupled automatics for 40+ years and never found them to be less efficient than my ability to have a manual in the best gear all the time. Have witnessed and been a passenger in vehicles where the instant high torque of a modern electric has caused a scare and in one instance damage. Ever been in an ID4 where the driver selected the wrong position on the rotarary direction selector before accelerating away?
After picking up 9 points in the space of two weeks (on a previously clean for 20 years license), on the same camera on the M62 variable speed limit stretch, I now drive like an octogenarian granny!! ......
Selecting 'Speed Limiter' or at worst 'Cruse Control' (not so useful in urban driving.) but a boon on the open road.
Never owned an automatic and have no intention of ever doing so, ..
Don't wait until anno domini creeps up on you, every few seconds gained in concentration on traffic junctions lights etc. with the background confidence that you are in the appropriate gear and the darn thing won't stall on you is an increased pleasure to a journey.
With cruise control you too can become the person driving at a constant speed in the range 60-69mph in the middle lane of the motorway oblivious to the frustration you are causing. I'm sure the combination of speed cameras and cruise control as a means of avoiding their attention has greatly contributed to this habit.
Well done for helping mate, i'm sure they appreciated it.
(y) we've known them more than 30 years but it's what any half decent person would do even if just off the street Mark, friends or not.
I rang to him this morning and in passing he said "I've got a present for you". "don't want it, not having it" I replied then he said "It's a plane which was my father's, still in it's box I wouldn't know how to use it, just need to blow the dust off the box from the crash".
"Thank's I'd love that I said" with my wife shouting in the background "He has enough bloody planes". :ROFLMAO::ROFLMAO:
But that's bad driving its not Cruise Controls fault, try the A40 from Gloucester to Abergavenny and on to A465 to Hirwaun and beyond and see how many miles you can cover with just a flick of the cruise paddles to adjust your speed rather than throttle or brake.
I don't know what the traffic is like round your way Chas, but hereabouts there's no 'increased pleasure' in any driving by car as a) there's a lot more of the bloody things on the road and b) those that are have got a hell of a lot 'fatter' (carspreading) than they were even a few years ago.
Most of my driving is done locally and whenever I do, it's almost invariably as early as I can make it, so I'm usually out the house to take SWIMBO to work (Fridays) at 7.00am and then round to Tesco & Waitrose before 7.30 so I'm back home having brekki by 9am, having gone round virtually empty supermarkets and roads with nowt on them.
A couple of days ago I went to pick up a new car seat for my little grandson and idiotically went round the bypass at mid-day, instead of taking the back road past Old Sarum. What should have been a 20 minute drive took 50 instead so please don't lecture me that an automatic gearbox is going to make a half-penny's worth of difference - Rob
Living in a more rural area than the inner environs of Salisbury it is precisely the aid of an automatic that I find most useful when tackling cities such as Bristol, Birmingham, Leicester (try there for a real challenge) when they become unavoidable, even Gloucester and Cheltenham can be interesting.
Not had the need to drive through Salisbury for a couple of years, usually use the park and ride at Wilton for visits there.
Careful - we know THREE octogenarian grannies and I wouldn't want to be in the car with any of them,.
At least, not without sedation.
The business about modern cars being a computer on wheels is dead right. Just over two years ago I bought a Nissan Qashqai. Nice car in many ways, good mileage and easy and comfortable to drive.
But.
It's been back to the main dealer twice already and I have an appointment in a couple of weeks for a third.
This time it's the telephony module of the NissanConnect operating system. As soon as I start the car, the dash lights up claiming that there is an incoming call from some geezer called Steve Maskery. I can't answer the call, because it is phantom, and if I reject the call, it lights up again after just a couple of seconds. I cannot access any of the menus in the system, I can't make or receive telephone calls and the voice operation of the SatNav doesn't work either.
The fix is straightforward enough, the software needs updating. It's a known bug, with a fix. But the car was serviced just a very few weeks ago, so why they didn't do it then, I don’t know. But every visit to the dealer is a morning or an afternoon lost.
I'm not impressed, TBH.
I commute Alnwick to Kendal fairly regularly and picked up three points recently on that awful A69 single carriageway (with passing lanes to get around H.G.V.'s) between Haltwhistle and Hexham. One of those "average speed" johnnies.
Result? Doing the course to avoid the points, but...not wanting to get nobbled again, I now rigorously use Croose Kontrol....amazing! I actually enjoy the run now! It's relaxing, I get time to think and contemplate. Don't under-rate c.c. - and the speed limits are there for a purpose!
A couple of those on the Fosse Way hills that make me cautious, so tempting with a poor mans turbo SRI until you remember that they are both in 40mph zones should someone be brave enough to stand with a hand camera.
@Lons
Amazing how easily a modern cavity wall is breached with a relatively slow impact, our local Doctors surgery wall was caved in last year by a vehicle that had mounted the pavement from the car park.
Having known 4 automatic gearboxes that would go into gear from neutral on their own, I now never leave an engine running in an automatic car.
One was an Austin Mini, the original design before BMW got hold of them, that went off backwards.( no Park position fitted) 3 others were farm tractors, good for front end loader work, but you never got off them, with the engine running, they were unreliable in which direction they’d go.
Bod1
Last couple vehicles I bought (pick up trucks) were automatics because that's what they had on the lot. If I wanted a manual tranny I would have to wait 3 to 6 months for it to come from the factory. Lots of vehicles here can only be had with automatic transmissions. My half ton Chevy Silverado is a 10 speed automatic.
Believe this or not, I was using Cruise control for BOTH!!!
So without trying to make this too long, there's a stretch of the M62 immediately as you come out of Manchester that has a variable limit, it was around 9pm in the winter, medium rain, I was a little tired after a long day in work and I had CC set to 69mph to make sure I wasn't tempted to speed.
I know exactly where the variable limit starts as there's a gantry showing it and also a 20' square sign on the side of the motorway that displays it and I categorically refute that EITHER were showing ANYTHING on them (unfortunately I don't have a dashcam...) but it was allegedly at 40mph. I remember it vividly, I was in the outside lane and doing the same speed as all the other cars because I remember there being a 7.5 tonner in front of me which I was very slowly creeping up on, but was only doing 1-3mph more than the cars in the middle lane. Flash Flash!
I was furious with it so I asked a Superintendent mate of mine (who just happens to head up the team who process these for GMP...) and he said to write in a letter of mitigation and they would be more lenient. I filled in the form to say yes it was me and awaited the second letter...and waited...and waited...my mate said if I don't get the second letter then often they haven't processed it in time and they cannot after two weeks. No letter, oh well I must have been lucky... I checked with Mr Google and there are hundreds if not thousands of FOI requests to the council for that stretch with every story being the same, gantry not indicating a change but flashed anyway. Answer to them all was the same, they are definitely working and there is a 40 second delay from the limit changing to camera being activated to avoid anyone getting caught after the limit changes...
A few weeks letter I get a letter to say I've been charged in my absence and received the maximum penalty because of that! Fuming but little to no recourse. Apparently I can get hammered for not defending myself, but by using snail mail and the letter never reaching me, meaning I had no chance to defend myself, is just tough...
To cap it off a couple of days later I get a rake of comedy messages from friends all knowing I'd been caught speeding! How? Oh, this is how...
Must have been a slow news day in Warrington...
Anyway, I'm significantly poorer but have driven like a nun (or insert your own timid and law abiding person here...) and have nearly cleared my name...!
I got caught by cameras once on the M1 in Derbyshire. I was driving home late at night, the motorway was almost empty. Speed taken down to 40 mph for "reports of object in the road". I saw the offending item clearly, an electrician's yellow stepladder safely on the hard shoulder (yes, they had such things in those days) as I passed it with the cruise control willfully set at 50. For this I did an on-line (in Covid) motorway awareness course - so I am now aware that the speed cameras do work all the time !
I was driving home after going to break the news to my old dad that his wife of 50 years, my mother, had died. I just wanted to be home. I had plenty of time to spot the offending item, that could easily have been handled by a short lane closure rather than a 40 limit going on for miles, and a lane closure would have made clearing the obstruction safer. But they would rather make money. None of that is of course an acceptable excuse.
