Ornamental lathe restoration
wallace
I made a start on my new lathe, it is going to take a while so instead of having bits laid around I got some storage crates.
The previous owner had done some work on it but there is still alot to do.
This is very different to my wadkin stuff. Its amazing what quality was achieved 150 years ago. I think the parts might have some kind of plating. It seems similar to the finish on carriage clocks, the silver section is nickel plated.
This is going to be fun to watch and I'm sure it will be beautiful and functional. Thanks for documenting it all.
On a slight tangent, I did a upgrade on my tent heater. The original twin wall flue did not give off much heat, whereas the single layer flue did. I had the bright idea of changing the flue to 6". I also played around with the minimum settings on the float valve. It now gives off more heat whilst using less fuel. I've been running it continuously for 3weeks and it uses about 25ltr a week. It is so nice to go into the workshop that isnt the same temp as outside.
Next up is this cross slide type affair. I think it holds a cutter which can be actuated by moving the lever.
Evaporust is great stuff
Got myself a copy of a scotchbrite wheel, the proper ones are pricey.
This was very pitted so it got a skim, I will mill new flats as well.
I'll follow this with great interest. You could consider joining the Society of Ornamental Turners - I think they would be very helpful if you need any help or advice.
Evaporust and a scotchbright seem to do wonderful work! Looking like new.
I’m like you I can’t work for long if I’m cold, it’s just about freezing in the workshop at the mo, and all I could stand was about an hour sweeping up and clearing up.
Not viable trying to heat the space at the mo, moving soon - more on this later.
Yes indeed, spot on. Get yourself a copy of Tom (T.D.) Walshaw's "Ornamental Turning", you'll get all you need in there to start you off. About a tenner, but it's all in there. If you fancy going further, same title, but by J.H. Evans is one of the original texts. Highly fallutin' (read pretentious) Edwardian or Victorian text, but cracking illustrations.
Mark, the third picture in this thread, slide rest top left, cutting frames centre ground and what I suspect, but do not have enough experience to definitively say, is a geometric chuck, or parts of it. on the right. The fourth image is, I think, an eccentric chuck.
Holtzapffel volumes 1 - 5 are available (in English) to download for free if you fancy trying to work out what it is he is trying to say and The Society of Ornamental Turners is alive and well too.
Try this: https://www.ornamentalturning.co.uk/ the third image shows the overhead pulleys and gearing in your first picture.
Sam
Thank you. That is a very good video. Dead simple.
And now I know why you have to plate steel with nickel first. Will now research silver plating.
Wallace, that is a great project…..I hope you have all the parts :unsure:
Dont know yet, I think the listing said the leadscrew was missing.
I was making the nickel solution and forgot about it.
It seems to be working
There are a couple of these bits which were very pitted.
I have a little eagle surface grinder
The finished article after being plated.
Another pitted part
After sanding with a powerfile, polishing and plating.
I tried re cutting the square on the screw but it didnt go very well. It took a while to realise it will be hardened. I think I will try the grinder.
Its been along time since I got to do any of this, been busy with other stuff.
The castings generally have a few voids, obviously you cant have holes in your ways. They are filled with a metal that is softer than the cast iron. I dont know the date of this but probably 19thC. Wadkin were still filling castings during their zenneth period in the 40/50's.
I had a piece of brass where the nickel was worn away, thought I'd try removing it by reversing the polarity
You end up with a grey sludge that comes off with scotchbrite
The next bit to start is this lump, not sure how or where it would go on the lathe, obviously some kind of cutting frame?
It has some really tactile curves, the fettling of the casting is quite impressive
I tried out a phosphoric acid rust removal
It worked quite well but I did panic when I first took it out and the part had a layer of grey soft stuff. I thought I'd dissolved the metal
Note to self, do not use aldi's masking tape. Supposed to be low tack, easy to remove. It aint, it stuck like a stucky stuck thing and deposited schmoo all over. I had to use acetone to get the adhesive off. I will stick with my yellow frog tape which is silly money but you can leave it for ages and it will still peal off easily.
I'm quite pleased how this turned out
Just lovely. Have fun using it.
S.
There are a lot more bits to clean up before I attempt to play. Plus I'm very new to ornamental turning. The SOT have some great footage but a lot of it is old being done by camcorder by the looks of it. Wifey was asking what I'd like for our wedding anniversary, SOT have some nice books that they have had reprinted.
That really is a thing of beauty.
3M blue masking tape always seems good to me (easy to remove after a long time in place).
Don't forget that you can get free, legal PDFs of old out of print books on ornamental turning. Even if you do decide to buy a reprint or an antique copy, rather than read on a screen, it's useful to be able to preview the whole book.
Search on archive.org and Google Books for authors such as Holtzapffel and John Henry Evans.
Exactly Sam. Who'd of thunked it, that I would be trying to understand the radius of a apocentral circle or the differential angle :unsure: . I managed a B in O level maths but this may as well be astro physics.
I found a book which makes it much easier to understand. Like not at all.
Using a Spirograph was never that complicated and the patterns created look the same;):)
Good luck.
I hope that you will be able to take a video of this machine in operation.
Good luck.
I loved my spirograph in the 70's. Not sure why you would need the maths to put a pattern on something. I think the piece of work is attached to this and moves around whilst a cutter spins attached to a cross slide.
Ordinarily I'd be a bit sceptical about this ever being fully restored to working order, but based on your track record and the work done so far I have no doubts whatsoever!
They look the same because it's the same principle that drives them both. The pencil in a Spirograph, and the cutter here, turn in lots of small circles while simultaneously also moving in a single large circle, at a fixed ratio to each other.
The difference is just that you need rather more rigidity in a lathe cutter than a pencil, so the mechanism needs to be more complex to hold it firmly enough while also moving to create the patterns. I believe the overall arrangement is that the cutter moves, either from side to side or in its own smaller circle, while the workpiece turns in the lathe; the multiplicity of gears and adjustments is to let you choose how many revolutions the cutting tool makes per revolution of the workpiece, and how far it moves with each one.
In that sense it's not very dissimilar from the change gears that are used for threading on a conventional metal lathe - lots of gears present, only a few actually in use at any one time and the actual task it performs is actually quite simple. The main difference from that one is that threading needs to choose between a relatively small number of fixed pitches, whereas this needs a much wider and more granular range of fractional speeds.
Going back to the Spirograph comparison, the gear selection is the same as the choice of inner gear; it determines how many small circles your cutter/pencil makes for each turn of the large circle. The eccentricities are the same as choosing which hole in the inner gear your pencil goes into; they determine the size of those small circles. The size of the large circles are determined here by how far from the centre line of the lathe you fix the cutting frame, and on a Spirograph by the choice of the large gear.
(It's a little more complex than that in the Spirograph case; rather than just the size of the small and large gears, it's the ratio between their sizes and the linear difference between them that affects those two factors, but I thought the simplification was easier to follow)
spb nailed it:
and that is how the O.L. was derived into Spiroraph.
Back on the lathe, a dense wood, fine grained, will show the intricate possibilities; save up "fish scales" until you have had a bit of practice.
Did you manage to get the cubical box of cutters too Mark? They really open up possibilities of patterning.
Sam
Its been a while since I did a machine and I am enjoying myself, its unknown if anything is missing. If I recall the original listing, the leadscrew is awol.
Sam I'm not sure, I've not gone through everything properly, I've just been grabbing a lump from a crate.
