Accipiter
- Joined
- Oct 16, 2025
- Messages
- 855
- Reaction score
- 636
- Location
- Frome, Somerset
- Name
- Frank
- LOCATION
- Somerset
Probably around 1990 I bought a half glazed door from the local B&Q - closed a couple of years later. The door had a damaged edge to one of the stiles so I got it for a good price. Thing is, it was 27" wide and I'd not realised we didn't have a doorway it would fit. Idea was to fit additional side stiles to gain the width.
Well... with the work on the workshop resurrection, the door was getting in the way - as it had over the last 35 years... waiting for the LOML to decide where she'd like it to be fitted. I dragged it out from the back storage area yesterday to check it over, expecting to find lots of worm holes and probably some rot! Two ww holes... no rot. So, measured up and checked the damaged stile - not as bad as I'd remembered on buying it. Decision made to rip 6mm from both and fit 2 ex 2x2 strips to make a width of 30".
The 2x2 x 2mt lengths purchased... finished sizes of 45mm sq. Door stiles are 35mm th... so planed to 35mm. Trimmed the damaged edge off as well as the opposite one. Needed to be done as the original edges had a slim rounded finish which would give a groove down the length of joining.
Next job is to make either slots/mortice for biscuits or drill for dowels at intervals along the edges and then glue and clamp... Then treat/paint (?) before fitting... It felt good to make some shavings today
