Still turning the images. Drives me crazy and puts me off WIP threads
Work so far:
Shift, stick up and label all wood. Including clear up storage area and have a bonfire
Remove quite a bit of cladding and bonfire it. (New verb "to bonfire")
Remove a part brick and part feather clad wall, gate and two deeply embedded posts.
Dig two deep corner holes.
Fit (very heavy) cement boards (for later cladding or rendering).
Re-locate nasty plastic downpipe. Temporary - will be changed to steel galvanised.
Clear off 2 cubic metres of limestone chippings, barrow away and brush site clean.
Lay sprinkling of sand, brushed over and then membrane material.
Shift quite a lot of concrete blocks and start doing formwork layout using scaffold boards.
Final layout still to be adjusted when my back feels less sore.
Next jobs will be finish the setting out dead on and mark levels.
Then lay mesh reinforcement before concrete lorry comes. Concrete not yet booked, but a big lorry can reverse in and drop from the chute. I have a magnesium float etc and we will get the slab done very quickly once the concrete arrives.
