It is currently 28 Mar 2024, 16:19
Andyp wrote:I read that garden furniture and camping equipment are/will be in short supply this summer too.
spb wrote:I can't help but feel that HS2 gets mentioned mostly because the average member of the public is more likely to accept it as an explanation than "all the shipping containers are in the wrong place so nobody can send us stuff".
Ultimately it comes down to a worldwide culture of companies chasing marginal gains in short-term profitability at the expense of long-term resilience. Covid just exposed the structural fragility of badly-implemented just-in-time supply chains that has been building for decades now.
Lurker wrote:Surely the U.K. is self sufficient for cement and plaster.
There was plenty in Wickes on Sunday.
novocaine wrote:wrong sort Andy, if you build your house with that it will fall down.
also, there appears to be a bird in it, which is quite frankly disgusting.
Trevanion wrote:Lurker wrote:Surely the U.K. is self sufficient for cement and plaster.
From what I was told there was no shortage of cement as such and if you wanted a lorry full if the loose stuff, you could. The problem was a complete shortage of the cement bags themselves of all things.
Doug wrote:Trevanion wrote:Lurker wrote:Surely the U.K. is self sufficient for cement and plaster.
That I can believe as I was told the shortage of plasterboard recently was down to lack of paper
MattS wrote:My solution to supply issues, yes i had to design around thin strips slightly but that’s about 9 sheets of ply for £250!
Doug wrote:Ironically I built a large wardrobe the other week & the cls in the stud work was more expensive than the 4 x 1 1/2” par redwood 5ths that I used for the door frames
