It is currently 29 Mar 2024, 02:59
oak table top movement
Postby sunnybob » 08 Jun 2021, 17:15
My oak table top is not behaving itself.
A few weeks after finishing it, there is unexpected movement.
The breadboard ends now are proud of the top surface of the table. Not a lot, but a definite ridge to the finger tips. Its as if the boards have shrunk.
Also on the edges of the table, the breadboard ends are also now proud of the boards by about a mm.
This is exactly the opposite of what I was told to expect. :eusa-doh:
sunnybob
Re: oak table top movement
Postby DaveL » 08 Jun 2021, 17:51
Well that has been caused by the main boards losing some moisture and therefore shrinking across the grain. If you have a damper season they may well swell back to be flush, that sort of movement is common with bread board ends.
Regards,
DaveL
Postby AJB Temple » 08 Jun 2021, 18:28
This is one of the reasons why I dislike breadboard ends. The fact that you have to build in a fitting system for movement tells you that .....you will get movement.
AJB Temple
Postby Woodbloke » 08 Jun 2021, 18:43
DaveL wrote:Well that has been caused by the main boards losing some moisture and therefore shrinking across the grain. If you have a damper season they may well swell back to be flush, that sort of movement is common with bread board ends.
:text-+1: :text-goodpost: - Rob
Return to General Woodworking
