It is currently 29 Mar 2024, 02:43
Mike G wrote::lol: I don't see it as a tool so much as a marking aid.
Doug wrote:Your angle pieces would be better round like the chap’s in the video, but then I guess you’d need a spar gauge to mark the timber to plane those pieces round
Or get a lathe
NickM wrote:That’s very clever. It’s obvious when he goes through the maths, but someone was very clever to come up with it. Have they been around for hundreds of years?
Andyp wrote:......Presumably if you want a tapered spar then the square stock needs to be tapered first?
Mike G wrote:Andyp wrote:......Presumably if you want a tapered spar then the square stock needs to be tapered first?
Yes, that's right. Just to complicate matters, they're often curve-tapered, if you like, rather than being a conic section. Entasis is the architectural term.
jimmy s wrote:The traditional shetland model boats were what I presume you would call clinker built Mike. They use a copper clink - like a nail that gets driven through the boards and is clinked in situ?. The smaller boats (fourareens - or 4 oared boats) are used for sailing in regattas up there still - they are based on old Viking boats I think. Traditionally they were built from larch or oregon pine but a lot of the new built ones are (or certainaly were when I still lived in Shetland) made of fairly thin marine ply boards, clinked up and were often coated in west systems epoxy from memory.
Always wanted to build a boat, but my Wife is not keen on the sea at all.
Users browsing this forum: No registered users and 26 guests
