It is currently 29 Mar 2024, 06:37
wooden hinges?
wooden hinges?
Postby sunnybob » 12 Dec 2020, 20:08
I want to make a pair of small wooden hinges for a box.
Nothing too complicated, but they need to be reasonably small (not medieval), no more than a couple inches long. I have 4 mm brass rod for a pin if needed.
Any one got any pics or places to look for ideas?
sunnybob
Re: wooden hinges?
Postby AJB Temple » 12 Dec 2020, 20:55
AJB Temple
Re: wooden hinges?
Postby Mike G » 12 Dec 2020, 21:01
So not like these, then.....
Re: wooden hinges?
Postby sunnybob » 12 Dec 2020, 21:39
Katz moses..... make hinges, no special tools. Just a drill and a BOX JOINT JIG. :o
Thats special as far as I'm concerned
Mike, I like those, but they are longer than my box is wide. Its a birdsmouth joint lozenge shape. I need a pair of external rear mounted hinges if they are going to fit the style.
sunnybob
Re: wooden hinges?
Postby novocaine » 12 Dec 2020, 21:39
novocaine
Re: wooden hinges?
Postby sunnybob » 13 Dec 2020, 07:37
I cant use those, my box is not 4 sided. As said above, I need rear mounted external hinges
sunnybob
Re: wooden hinges?
Postby Lurker » 13 Dec 2020, 18:08
IIRC
Pete Maddex posted a small u tube or similar of some he made for small boxes.
Try pm ing him
Lurker
Re: wooden hinges?
Postby sunnybob » 13 Dec 2020, 19:47
I think I'm going to have to re-think.
I've now completed and glued up the box and its pretty shallow. I cant see me making wooden hinges small enough to be in keeping with the box.
I'm pretty sure I still have a couple of brass hinges in a box somewhere. 8-) 8-)
sunnybob
Re: wooden hinges?
Postby Lurker » 14 Dec 2020, 12:12
How about these?
https://www.amazon.co.uk/WoodRiver-Mini ... B0035Y44BO
I have not used these specific ones.
Lurker
Re: wooden hinges?
Postby droogs » 14 Dec 2020, 19:49
have you thought about using laptop hinges from an old knackered machine
droogs
Re: wooden hinges?
Postby sunnybob » 14 Dec 2020, 20:35
Have to admit I havent.
But thats mostly because the only old knackered laptop i have is the one I'm typing on right now. :lol:
sunnybob
Re: wooden hinges?
Postby Pete Maddex » 14 Dec 2020, 21:13
Yo Bob.
https://www.facebook.com/peter.maddex/p ... 4716999776
You can use them for boxes like this.
ImageRipple ash bog oak and brown oak box by Pete Maddex, on Flickr
Or small boxes.
ImageLacewood box by Pete Maddex, on Flickr
Let them eat static
Flickr
Pete Maddex
Re: wooden hinges?
Postby garno » 14 Dec 2020, 21:41
Those boxes are stunning Pete :eusa-clap: :text-bravo: :text-bravo:
The older I become the more things I find wrong the young.
garno
Re: wooden hinges?
Postby Lons » 14 Dec 2020, 21:59
VERY nice boxes Pete :eusa-clap:
I have a degree in faffing about (It must be true, my wife says so)
Lons
Re: wooden hinges?
Postby Pete Maddex » 14 Dec 2020, 22:01
garno wrote:Those boxes are stunning Pete :eusa-clap: :text-bravo: :text-bravo:
Thanks mate.
Let them eat static
Flickr
Pete Maddex
Re: wooden hinges?
Postby sunnybob » 14 Dec 2020, 22:05
Very neat and will definitely remember that for future use, but this box is an 8 sided lozenge shape and I cant see a way of inserting the pins through a 45 degree angle.
I shall have to use brass butt hinges mounted on the outside on this one. As usual, I didnt work anything out in advance. ;)
sunnybob
Re: wooden hinges?
Postby Pete Maddex » 14 Dec 2020, 22:40
Ho Bob
How about these.
ImageHinges by Pete Maddex, on Flickr
ImageHeart ring box by Pete Maddex, on Flickr
ImageHeart ring box open by Pete Maddex, on Flickr
ImageHeart ring box waxed by Pete Maddex, on Flickr
The hinge pins are soldered into one side of the brass plate, do opposite ones so the lid won't slide off.
Let them eat static
Flickr
Pete Maddex
Re: wooden hinges?
Postby sunnybob » 15 Dec 2020, 07:04
Ah, now that is interesting and do-able.
A lot of work though as the only brass I have is 3/4" x 1/2" bar.
I havent checked what hinges I have yet. If I dont have any useful ones to hand I can see a lot of filing in my near future.
Thanks Pete. 8-)
Did you use 2 part epoxy to hold the brass in? I wonder about long term holding properties between metal and wood.
sunnybob
Re: wooden hinges?
Postby Pete Maddex » 15 Dec 2020, 08:04
Hi Bob
Yes two part epoxy, I have had no complaints.
You can drill another hole through the brass to form a glue tenon, I use them on wooden key fobs and it makes a very strong joint.
Some sawdust mixed in with the glue hides any mistakes.
Let them eat static
Flickr
Pete Maddex
Re: wooden hinges?
Postby novocaine » 15 Dec 2020, 08:37
I reckon you could get enough metal from a couple of coins to make those hinges. :P
novocaine
Re: wooden hinges?
Postby sunnybob » 15 Dec 2020, 10:00
I've found a reasonably nice pair of normal brass hinges in my oddsnsods box that need using up.
This box is fairly substantial (50 cm long x 15 cm wide) and I worry the lid weight might pull those little brass plates out of the wood so I will fit the standard ones here, but I'll definitely design the next one around those brass pivots though. 8-) 8-)
sunnybob
Return to Tips & Tutorials
