It is currently 28 Mar 2024, 19:11
NickM wrote:When you shoot yours, how do you make sure opposite box sides remain the same length?
ScaredyCat wrote:Any reason not to cut 4 splines at once?
ScaredyCat wrote:Clamping the 4 pieces side by side for the spline cut.
Steve Maskery wrote:ScaredyCat wrote:Clamping the 4 pieces side by side for the spline cut.
I think that clamping them p and making sure that there were all perfectly aligned would take longer than doing them one at at time, TBH, Andy. And if you clamp them, how are you going to hold them against the fence of the jig without the clamp itself getting in the way?
Woodbloke wrote:As a non-tablesaur user, I chop of most of the waste on the bandsaw and then go straight onto the mitre shoot. I use a little jig on the router table to insert a spline on two, in much the same way as you'd do for a picture frame, after the box mitres have been glued - Rob
ScaredyCat wrote:Steve,
I tried out your spline shim cutting method and although some of them were a close fit, most were still sloppy - and clues as to the cause and any ways to ensure a better fit?
ScaredyCat wrote:Ohh, I can't remember if I did that. Do you class 2 cuts as forward and back?
9fingers wrote:I presume from the context it is some of your kerf cuts are too wide not that some splines too thin?
