It is currently 29 Mar 2024, 00:57
Simple little things
Postby Lurker » 16 May 2021, 10:53
Thought that I would try to start a thread about small simple tricks that make life easier.
About 20 years ago, I came across a bag full of m10 stainless steel nuts and obviously put them in the “come in useful one day” drawer. When I open a can of say, danish oil, I drop a nut in the tin, this helps the subsequent “shake well before using” process.
Lurker
Re: Simple little things
Postby droogs » 16 May 2021, 11:23
If using perspex etc and it has a few light scratches, I use a trick from my younger days making models and use toothpaste to polish the scratches out. Lot easier to grab the toothpaste than try to find something proper
droogs
Postby 9fingers » 16 May 2021, 11:55
When I find as small gap in a woodworking joint (very rare naturally :eusa-whistle: ) I put a little pva glue in the gap and sand the area with fine grit say 180 with the ROS. The dust colours the glue with just the right shade of wood fit a near invisible fix.
I find this far better than making up a wood dust and glue filler.
Postby Chris101 » 16 May 2021, 12:12
Not woodworking but a useful tip nonetheless.
Ever struggled to find your car in a busy car park?
Simply let your tyres down and hey presto when you get back from shopping at IKEA or off the plane in the longterm car park just look for the lowest car. Simple and useful.
Chris101
Postby John Brown » 16 May 2021, 12:22
Chris101 wrote:Not woodworking but a useful tip nonetheless.
You should send that to Viz magazine( if it didn't come from there in the first place). :D
John Brown
Postby Woodbloke » 16 May 2021, 13:30
Here's a good little tip...really, but really think about what you're doing. I had to exercise the 'little grey cells' for an hour or two this morning to find a 'fix'; had I not, two new bits of oak would have been needed :cry: - Rob
Postby 9fingers » 22 May 2021, 09:30
When using bearing guided router cutters.....
Put a couple of layers of masking tape round the bearing when doing the first cut. Once all your pieces have had the first cut, take off the tape and you can then do a final fine cut to size.
Helps get a finer finish as well as remove any scorch marks on difficult timbers like beech.
Postby Phil Pascoe » 22 May 2021, 09:41
If your moulding is simple with no undercuts such as an ovolo, quite often you can run the moulding before the final clean up of the surface then leave the router on the same setting and the slight difference on the depth will clean it up with another pass.
Phil Pascoe
Postby novocaine » 22 May 2021, 12:44
345
If theres slag its best to drag.
Superglue and masking tape.
Its just a bench.
novocaine
Postby NickM » 22 May 2021, 14:30
John Brown wrote:You should send that to Viz magazine( if it didn't come from there in the first place). :D
That reminded me that I have this on my bookshelf:
(518.01 KiB)
Alongside my copy of Roger's (different Roger (I think...)) Profanisaurus:
(500.16 KiB)
NickM
Return to Tips & Tutorials
