It is currently 28 Mar 2024, 10:06
Spirit level bubble
Spirit level bubble
Postby Lurker » 15 Aug 2021, 09:11
I have a nice spirit level with one of the bubbles broken. Yesterday I found amongst my junk tools a cheap level and thus a donor bubble.
I think traditionally bubbles were set in putty.
Anyone got suggestions for setting compound?
I don’t want to use plaster incase I need to adjust before the stuff goes off. Think epoxy could end up messy.
Lurker
Re: Spirit level bubble
Postby 9fingers » 15 Aug 2021, 09:50
Use small pads of blu tack to adjust until you are happy with it then use a permanent fix according to what you have in stock.
Postby Lurker » 15 Aug 2021, 10:54
The bubble was the one that measures vertical.
The housing was a fiddly channel.
I have (just) used sealastic, it was messy but I think that I have got it right.
I am fixing a 2ft aluminium Rabone, after bending my go to cheapo from tool station.
I was going to get another, but they are no longer cheap!
I do have a very nice stabila for important stuff.
Lurker
Postby droogs » 15 Aug 2021, 11:50
Usually it's plaster of paris in the old torpedoes etc. So I would suggest a bit of Polyfilla from one of those wee tubes for a £1
droogs
Postby AndyT » 15 Aug 2021, 16:51
Polymorph?
AndyT
Postby sunnybob » 15 Aug 2021, 17:50
I have a really nice 6" spirit level. Its a wooden boat tail shape, and both bubbles are screw adjustable so whatever you do its always square. :lol:
sunnybob
Postby Lurker » 15 Aug 2021, 18:11
AndyT wrote:Polymorph?
I did think about it.
Lurker
Postby Lurker » 15 Aug 2021, 18:19
(198.86 KiB)
I had to piddle some excess off the tube but it has worked ok
It was the bubble to the left.
Lurker
Postby Lurker » 15 Aug 2021, 18:21
Not sure what happen there :o
Lurker
Postby Andyp » 15 Aug 2021, 18:51
Lurker wrote:Not sure what happen there :o
I removed the duplication and sorted the rotation.
When you notice an image on your post has been rotated simply download and save that image back to your device, rotate it, save it then edit your post deleting the rotated image and upload and place in line the edited one.
Postby Lurker » 15 Aug 2021, 19:07
Thanks
Lurker
Postby forrestmount » 17 Aug 2021, 10:12
In a former life I repaired survey equipment. We always used plaster of Paris for setting bubbles
Sent from my iPad using Tapatalk Pro
forrestmount
Return to Hand Toolery
