It is currently 29 Mar 2024, 12:05
Firmer chisels.
Firmer chisels.
Postby Mike G » 30 Dec 2021, 18:33
What are they?
I mean, I know what they are, sort of, but is there a definition? I've seen bevel edge chisels described as firmers, which had me a little puzzled. I've seen butt chisels described as firmers....and I can see that this might be plausible.
Re: Firmer chisels.
Postby DaveL » 30 Dec 2021, 18:41
I think they have square sides but then might be wrong?
Regards,
DaveL
Re: Firmer chisels.
Postby Woodbloke » 30 Dec 2021, 18:41
Mike G wrote:What are they?
A proper 'firmer' chisel has a cross-section which is truly rectangular. Anything else is a 'bevel edge' where the sides may be very finely ground (LN or Veritas) or quite coarsely machined (plenty of examples) - Rob
Re: Firmer chisels.
Postby Trevanion » 30 Dec 2021, 19:58
As Rob said, they're basically just plain square/rectangular in cross-section chisels, with no bevels ground onto them. I would assume the name "firmer" comes from times gone by as back in the day beveled edge chisels were properly beveled edge (much like the premium stuff you can buy now) and quite delicate for heavy work, so "firmers" are a stronger chisel than a beveled edge. I think firmers were a much more preferred chisel for site work by a carpenter/joiner pre-plastic handles and thicker beveled edge chisels, especially the even more heavy-duty "Registered Firmer" chisels. The only thing I've noticed with old firmers is that they're much thinner than modern chisels such as the ones made by Stanley or Marples which are beveled edge.
AndyT, AndyT'N'T, Alf, or anyone else that's of a vintage hand tool persuasion would probably know more.
Trevanion
Re: Firmer chisels.
Postby Blackswanwood » 30 Dec 2021, 20:56
Is it not the case that a registered firmer chisel typically has a leather washer and the handle has a metal hoop so it doesn’t split when it’s clobbered?
Blackswanwood
Re: Firmer chisels.
Postby Mike G » 30 Dec 2021, 21:00
Blackswanwood wrote:Is it not the case that a registered firmer chisel typically has a leather washer and the handle has a metal hoop so it doesn’t split when it’s clobbered?
One of the nicest chisels I've ever used was like that......but had a fine, thin, bevelled 1-1/2" blade (blade? Is it a blade?). A firmer-type handle with a very fine steel thingamejig. And obviously, being an inch and a half, it wasn't designed for pushing around by hand.
Re: Firmer chisels.
Postby AndyT » 30 Dec 2021, 21:44
I think there are two questions tangled up together here, each interesting in its own way.
One is "What forms of chisels have been made, over time and in different countries, exploiting the means of production available and serving the different needs of the trades where they were used?"
The second question is "How did the makers, sellers and users refer to the various sorts of chisels available in different times and places, so as to distinguish between them, and when they referred to a firmer chisel, what did they mean?"
As a brief response, I'll suggest that "firmer chisel" has generally meant the ordinary bench chisel of the carpenter and joiner, but at different periods the tools being referred to won't all be the same.
We could work together on a longer answer.
AndyT
Re: Firmer chisels.
Postby Blackswanwood » 30 Dec 2021, 22:24
I think you are right Andy. From a bit of searching over the last hour it seems a firmer chisel was originally a reference to differentiate the way the chisel was made. If what I have read is correct “ordinary” chisels were made from iron with a steel laminate but firmer chisels were solid steel with square edges and hardwood handles designed for heavier duty use.
Blackswanwood
Re: Firmer chisels.
Postby Woodbloke » 30 Dec 2021, 23:40
Blackswanwood wrote:...firmer chisels were solid steel with square edges and hardwood handles designed for heavier duty use.
Just like these :D I know these are firmer chisels 'cos I bought the same brand new, boxwood handled Marples set in the 70's and they were sold as 'Firmer Chisels' - Rob
Re: Firmer chisels.
Postby Trevanion » 31 Dec 2021, 00:00
I'm rather confused now also!
I've got an old Marples catalogue from the 1930s that I bought donkeys years ago which I had a look through just to see what it says on the matter and it has "Firmer Chisels" and "Beveled Edge Firmer Chisels"
I feel like my whole understanding of woodworking has been turned on its head!
Trevanion
Re: Firmer chisels.
Postby Blackswanwood » 31 Dec 2021, 00:11
Trevanion wrote:I'm rather confused now also!
Presumably thicker than a normal bevelled chisel?
(201.43 KiB)
Blackswanwood
Re: Firmer chisels.
Postby Blackswanwood » 31 Dec 2021, 00:16
So at what point does a firmer chisel become a mortice chisel Rob?
Blackswanwood
Re: Firmer chisels.
Postby Trevanion » 31 Dec 2021, 00:19
Blackswanwood wrote:So at what point does a firmer chisel become a mortice chisel Rob?
Well I would've thought once the chisel's thickness is greater than its width it becomes a mortice chisel but after these revelations today I wouldn't be surprised it's something completely different!
Trevanion
Re: Firmer chisels.
Postby Alf » 31 Dec 2021, 09:32
AndyT wrote:I think there are two questions tangled up together here, each interesting in its own way.
All this. Except the last bit, because I'm not sure mass insanity should be encouraged... :lol:
Demonstrating your understanding of the problem.
I've long given up trying to make a definitive statement as to what makes a chisel an "X" or a "Y", because chances are there's another chisel that's the exception that proves the rule - and thus finds the rule wanting. At the very least you need a time frame in which you wish to place your definition, as Andy rightly says.
Alf
Re: Firmer chisels.
Postby Woodbloke » 31 Dec 2021, 10:04
To my way of thinking, as I mentioned above, a 'firmer' chisel has a true, rectangular cross-sectioned, blade. When the blade is still rectangular in section, but maybe slightly chunkier and the handle has a leather washer and steel ferule on the end (aka Japanese style) it's a 'registered firmer' and is made for sustained, heavy duty chopping.
A mortice chisel still has a rectangular or square cross-section (depending on size), but in use it's turned through 90deg, the extreme example being the traditional 'pig sticker' type, where the cutting edge could be say, 6mm wide but the depth from front to back much deeper, say 10 or 12mm.
The variations between the different types/styles are obviously open to individual interpretation, but that's the way that I've always classified them - Rob
Re: Firmer chisels.
Postby Phil Pascoe » 31 Dec 2021, 11:18
That's a well made bevel edge chisel and a not very well made bevel edge chisel. :D
Phil Pascoe
Re: Firmer chisels.
Postby Raymedullary » 31 Dec 2021, 12:55
As has been said, to understand the different terms, think of it as an evolutionary/historical thing.
Firmer were general use chisels.... some chopping light morticin
(163.23 KiB)
g perhaps. Alongside these were bevel edged. These were the pure bevel edge, usually quite thin on their edges. This allowed for fine work e.g. paring between dovetails. Then as things changed and people wanted a general purpose tool that could be hit but also nicer to use for paring. Thus the birth of the former bevel edge chisel.
(333.87 KiB)
Raymedullary
Return to Hand Toolery
