It is currently 29 Mar 2024, 06:10
novocaine wrote:You add the relay so you can have a flip flop state change. Push once it goes up push again and it goes down. The issue i cant figure is the 3 states up,off,down. But leave it with me.
Just like you asked for.
Mike G wrote:Do we have a means of posting video of our own stuff here? I'm just imagining pushing the carving and the TV popping up, then pushing it again and it putting itself away.........and none of you buggers believing me! Seriously, I manage to take the occasional video by accident, so I'm sure I could manage to take one on purpose. What then?
Pete Maddex wrote:Mike you need a flip-flop to switch a relay and limit switches to stop the motor at each end.
https://www.ebay.co.uk/itm/1PC-6-24V-Fl ... 0005.m1851
I will try and do a diagram tomorrow.
Sheffield Tony wrote:This sounds tricky to me. I'm an electronics type so would normally turn to an electronic solution rather than mechanical. If you use separate limit and reversing switches, you have to take care they both get triggered - so it doesnt hit the reverse switch first and sit bobbing up and down, or hit the limit switch and stop before hitting the reverse, so get stuck.
