It is currently 29 Mar 2024, 07:02
Lurker wrote:https://www.ironmongerydirect.co.uk/product/adjustable-gate-eye-200mm-for-19mm-pin-galvanised-417409
Lurker wrote:I thought that you wanted a threaded bar to epoxy into the wall.
You could use these if they are long enough, and then put a bolt through the eye of this and also the “gate eye”.
Mike G wrote:.....A wonky old wall will mean you need adjustment, and so a shaft epoxied into a hole for each hinge will give you a chance of getting the gate in the right place. So, a bit more info, or a photo or two....
RogerS wrote:Mike G wrote:.....A wonky old wall will mean you need adjustment, and so a shaft epoxied into a hole for each hinge will give you a chance of getting the gate in the right place. So, a bit more info, or a photo or two....
You've got it in one, Mike.
novocaine wrote:I shall get you a drawing this evening (I haven't got a fag packet in work) and then get started.
cover postage only, if you don't mind.
RogerS wrote:novocaine wrote:I shall get you a drawing this evening (I haven't got a fag packet in work) and then get started.
I don't mind at all. Donation also to a charity of your choice perhaps ?
novocaine wrote:RogerS wrote:novocaine wrote:I shall get you a drawing this evening (I haven't got a fag packet in work) and then get started.
If you feel the need, but it isn't compulsory and you can pick a charity. I prefer my donations to charity to come from the pot I put to the side and remain my own business, don't ask why, I'm just weird.
RogerS wrote:Absolutely spot on, Dave
novocaine wrote:RogerS wrote:Absolutely spot on, Dave
Cool. I'll get them sorted over the weekend.
RogerS wrote:novocaine wrote:RogerS wrote:Absolutely spot on, Dave
Thanks Dave. The length of the screwed thread part? Probably 75mm? Is that OK ?
novocaine wrote:RogerS wrote:novocaine wrote:Cool. I'll get them sorted over the weekend.
Yep, though it won't be a perfect thread for the last 25mm as I'm cheating a bit and using a coach bolt, save me having to cut threads and better steel than threaded rod. I'll leave them a tad long so you can make of it what you wish. Or I can flip it round and have 50mm off thread on the end with a clear shank on the middle.
