It is currently 29 Mar 2024, 11:39
Andyp wrote:Thanks Derek,
That then begs the question. Where will you be running yours?
Dalboy wrote:I did approach management but that was turned down straight away so I did not submit planning for it
CHJ wrote:Judging by your progress to date I think you need to put more time into management manipulation.
If you are to get the most out of the build, just in case of course, you are forced to take days out to run it off site, don't want testing away from base to impact on any future "can you just sort this out" events that management might have do we.Dalboy wrote:I did approach management but that was turned down straight away so I did not submit planning for it
CHJ wrote:Full marks for progress and machining quality, but your enthusiasm for workshop output is frustratingly embarrassing.
Dalboy wrote:The big question is "Are there enough hours in the day"
SamQ aka Ah! Q! wrote:Nice methodical work Derek. Very true to 'the real thing'.
NickM wrote:This is great work. I think you may have said already (I’m too lazy to read back), but are you making your own boiler?
Dalboy wrote:Thank you allNickM wrote:This is great work. I think you may have said already (I’m too lazy to read back), but are you making your own boiler?
Yes I will be I will also join a club near me not only to have it tested but also to chat and be able to run it on a track
CHJ wrote:Great work Derek, not only impressed with the quality of finish but also the hours you are allotting to the project.
Users browsing this forum: AndyT and 6 guests
