It is currently 28 Mar 2024, 17:15
Doug wrote:Bob you link doesn’t take me to your video just a list of random videos
Excellent thread Bob!9fingers wrote:Induction motors are the quiet (ish) ones usually with a capacitor(or two) on the side and almost certainly on fixed machinery.
If the machine is portable, noisy, under say 2000watts and has brushes and a commutator, it is a universal motor and suitable for use with this soft start type system.
HTH
Jonathan wrote:Excellent thread Bob!9fingers wrote:Induction motors are the quiet (ish) ones usually with a capacitor(or two) on the side and almost certainly on fixed machinery.
HTH
Out of curiosity would this work on bigger motor's like a 2 to 3 kw spindle moulder or extractor?
the bear wrote:No part of it is unclear, just a hypothetical question from me. Sorry Bob
9fingers wrote:Yes it is a brush motor and not an induction motor **so in theory suitable. I can’t read the current rating on the motor plate though. The module I used is marked as 20amps but I’d like to see a bit of a margin between the motor rated current and the max for the device.
Assuming your machine runs from a 13 amp plug comfortably then you should be fine
**it is just possible your motor is a repulsion start motor, about the only induction motor I know of with brushes
9fingers wrote: I settled on one reputed rated for 20amps thinking that would be more than enough to handle most of my brush motor tools including the inrush current.
This is the unit I bought https://www.aliexpress.com/item/1005003 ... 1802pENSnr
There are several types but make sure you get a two wire one for ease of use
CHJ wrote:9fingers wrote: I settled on one reputed rated for 20amps thinking that would be more than enough to handle most of my brush motor tools including the inrush current.
Bob, do you know how the internals function using just 2 'In & Out' wires.' Is it just a thermal 'Negative' resistance module' ?
All devices I've ever used where 3wire, and ones with a heat sink/mounting tab used the Tab as the ground reference.
John Brown wrote:On this subject, I'm hoping to be able to run my saw(1600W) and/or my bandsaw(450W) from a 3 or 4kW pure sine inverter. One of the inverter manufacturers says their Inverter has a soft start, and that turning on a large appliance before starting the inverter helps with startup. Obviously this won't work with NVR controls. Would a soft start module help in this case?
