It is currently 29 Mar 2024, 16:41
9fingers wrote:I can't see a problem. Seems so straight forward I'm left wondering if I've over looked something.
What is your concern causing you to ask?
Guineafowl21 wrote:9fingers wrote:I can't see a problem. Seems so straight forward I'm left wondering if I've over looked something.
I’m not sure where I would take it to get done. Also, I haven’t seen any SMs for sale that have had this done. Why would you keep a 11/4 shaft when 30mm opens you up to a massive range of modern tooling, and a couple of £20 bushes allow you to keep the old tooling? I wondered if the shafts were hollow and not machinable, too.
I’m looking to upgrade from my Charnwood cheapo model, which has been extremely usefuI, but can’t find a decent spindle that has a flush sliding table.
Guineafowl21 wrote: - Power 2hp, could do with a bit more since it has stalled on some big architrave mouldings I’ve been doing for someone.
Guineafowl21 wrote: - Table is a bit small - roller stands can only do so much.
- Fence is awful.
- Rise and fall has more backlash than an old Land Rover
Guineafowl21 wrote:Ideal spindle moulder:
- 30 mm shaft
- Flush sliding table with clamp
- Tilt possibly useful, but not essential
- Under £1000
Doug71 wrote:I replaced an Elektra Beckum spindle moulder that had a 30mm shaft with an old Wadkin BER2 which luckily came with a few 11/4 blocks, the blocks cover all I need really so I lent a friend my 30mm blocks, don't know if I will ever see them again!
The BER2 is a nice piece of kit, basic but does all I need, a sliding table would be nice though.
It looks like AMS will sell you a replacement 30mm shaft, only £335+VAT........
https://www.advancedmachinery.co.uk/mac ... s-8337-224
Guineafowl21 wrote:Back to my original question - why would anyone pay that amount if the shaft can be machined for a reasonable price?
Trevanion wrote:
AMS like most spares merchants, are overpriced. A belt you can buy from a belt supplier would cost you £10, but it will cost you £30 with AMS.
wallace wrote:I've been having a purge of junk, I mean spares, I came across a few spindles but haven't checked sizes yet. I think they might be off an EQ spindle.
RogerS wrote:Wouldn't it be quicker/better/cheaper just to buy a couple of used 1 1/4 blocks off eBay ?
9fingers wrote:wallace wrote:I've been having a purge of junk, I mean spares, I came across a few spindles but haven't checked sizes yet. I think they might be off an EQ spindle.
Mark. If you don’t have one I wonder if doubleboost John might be able to do the machining for the op?
wallace wrote:9fingers wrote:wallace wrote:I've been having a purge of junk, I mean spares, I came across a few spindles but haven't checked sizes yet. I think they might be off an EQ spindle.
I'm sure John would be up for doing it, He's changed job recently to give himself more time tinkering.
I'm sure I know some one who has recently done this to a spindle.
Guineafowl21 wrote:Here is the machine, if anyone’s interested:
https://www.ebay.co.uk/itm/334004339335 ... SwH8FgolMT
Reading between the lines, and looking at the price, it will probably need some work, and doesn’t appear to come with spacers or top nut. The T slot might just replace the sliding table, if I can find a track to fit.
Guineafowl21 wrote:I saw that SCM - wondered why all the pics are blurred and repeated. Not a careful owner, by the look of things.
I’ve sent a few questions, anyway.
Guineafowl21 wrote:Well, I put in an offer on the Wadkin, but it expired. I chased the seller, then the listing was ended ‘because the item is lost or broken’.
Weird.
Guineafowl21 wrote:(SCM t120C)
(SCM t110)
(Sedgwick SM3ii)
Guineafowl21 wrote:The T110 has no brake so I assume it’s cheap because it can’t be used in a workplace, but is too big for a hobby shop. I know of a Crompton DC brake, 4kW, on sale secondhand. I’m tempted to buy it, tart it up, fit a brake and sell it on.
