It is currently 29 Mar 2024, 00:49
Cncpaul wrote:Would hinged from the wall be a better option ?
droogs wrote:What about a tablesaw/router bed flip top stand on a slowmo motor connected to a PA that plays Thunderbirds each time you change use? That's what I'd do, honestly
If you can't be bothered then provided your rafters are big enough go with the pulleys
Andyp wrote:Once you have it hoisted what will the clearance underneath be? How tall are you? Will moving stuff around the workshop be a problem?
I’ve not a better solution other than a workshop extension.
9fingers wrote:I have a small (5' x3') road trailer stowed in my garage roof hauled up by winch and rope but once in position, the weight is taken by short chains and the tension taken off the rope.
Something similar as a safety measure might be appropriate here too?
9fingers wrote:Just occurred to me that if you had an inverted box structure on the ceiling that you winched the cnc on it's table up into to form a sealed box, it would keep it virtually dust free.
Toggle clamps around the box would both keep it shut and take the weight off the ropes as well as dealing with any chance of rodent issues.
sunnybob wrote:Youre over estimating weight problems. Again, 50kgs (assume 60 including the actual pulleys and ropes) across two beams. 30 kgs per beam. If you were fit and able, would you be prepared to chin yourself up on each beam? Thats about a 100 kgs per beam.
I would not use galvanised wire, galvanising is a very thin top coat over iron. A few lifts and lowers over steel pulleys could easily crack the galvanising, leading to early onset rust in shed conditions.
Very thin stainless cable, and ALL of your maintenance goes away for the rest of your life.
Malc2098 wrote:
In addition, they say that the bluetooth connection is more stable because it's not susceptible to EMI interference.
That statement stretches their credibility somewhat. A wireless link almost never offers greater EMI resistance than a directly connected cable.
As you know from your Wifi experience in the workshop, EMI from your lights caused lots of issues.
Certainly reducing/removing cables draped across the shop is highly desirable so that is a positive.
Andyp wrote:How long did that take Malc?
RogerS wrote:Andyp wrote:How long did that take Malc?
Six months to build the machine. Five more to get it working. Four hours on the computer writing the instructions. 30 seconds making it.
Sorry, Malc...couldn't resist. I'm seriously impressed with what you've done.
