It is currently 29 Mar 2024, 15:28
Andyp wrote:With apologies to Rory Schieder, you’re gonna need a bigger workshop.
Malc2098 wrote:Andyp wrote:With apologies to Rory Schieder, you’re gonna need a bigger workshop.
We all do! So what's new?!!
Robert wrote:Read somewhere the water cooled spindle/router is quieter than the air cooled. be interesting when you run yours to see what you think. Got to be much better than a normal router in any case.
Malc2098 wrote:......., there isn't really a definitive installation manual.
But there are several source of how others have done it, which I have viewed and read many times, so it's about time I got going.
Malc2098 wrote:The safety circuit I'm trying to achieve here, is to cut the power to the VFD and hence the spindle (230v), but leave power to the controller (24vDC), so that I can reset the job.
Robert wrote:Malc2098 wrote:The safety circuit I'm trying to achieve here, is to cut the power to the VFD and hence the spindle (230v), but leave power to the controller (24vDC), so that I can reset the job.
Can you explain that a bit more please.
How does stopping the spindle help anything? If the axes are still moving a stopped cutter will do nearly as much damage to the workpiece as a moving one. Don't you need an emergency pause button?
On the metal punching CNC that meant pressing the single step button. Then you'd have to press start for every line of gcode to progress and could sort out a bent edge or whatever at leisure. E stop was for when the sheet of metal got screwed up and the program abandoned.
Robert wrote:
Stupid question - you have a stop button - is there a physical cycle start button...single step button etc that I remember or is it all software initiated - click go on a PC screen or similar?
novocaine wrote:check in the controller manual before you go to much further on the spindle stop Malcolm. A lot of modern controllers have a restart after power loss. unlike the good old days, the code is stored in eeprom rather than RAM, so it remembers it's last known position. It also normally starts back up in manual override to so you can jog through the code and check it's position before it starts again. I swear that black magic is at work to do this.
