It is currently 28 Mar 2024, 14:14
9fingers wrote:One thing to look at on your inverter *might* be the following.
Most inverters need their front panel controls disabled before they will work with the digital inputs. About the only one allow to stay effective with external control enabled is the stop button.
Good Luck
9fingers wrote:The z error could be caused by missing steps or a bit of unwanted flexing of the gantry
I presume there is negligible end float in the spindle itself.
Robert wrote:Well done
Next challenge to make something you designed and coded from scratch? Even if it is just a rectangle.
Users browsing this forum: No registered users and 26 guests
