It is currently 28 Mar 2024, 13:16
Loose tenon joints (without a Festool Domino)
Postby Weekend_Woodworker » 04 Jan 2022, 23:32
Has any one any experience of using loose tenon joints without a Festool Domino ( I would quite like the Festool one, but haven't yet convinced myself to part with that much money)?
I came across this:
(304 KiB)
It is can be bought here:
https://www.aliexpress.com/item/1005003 ... mainSearch
and seems very cheap, so was tempted to give it a try.
I was also wondering about a good source of wooden loose tenons to use with it. Is there a good place to buy them or do people buy a suitable bead cutter bit for them and make their own?
Any advice and thoughts welcome.
Thanks, Mark
Weekend_Woodworker
Re: Loose tenon joints (without a Festool Domino)
Postby RogerS » 04 Jan 2022, 23:50
Gosh, Mark. That's a hard call given the price. But TBH at that price, I'd try it.
Having said that....when you buy into the Domino, you're buying into a whole new 'ecosystem'.
Postby spb » 05 Jan 2022, 00:46
I've not needed to, but I think if I did I'd look at making one of these:
Mod edit:- for those that can't view directly here is the URL
https://www.youtube.com/watch?time_cont ... e=emb_logo
Reason: mod edit, URL added
spb
Postby Weekend_Woodworker » 05 Jan 2022, 20:27
Hi Stephen,
The link in your post appears to be missing. Are you able to re-post it?
Thanks
Weekend_Woodworker
Postby Weekend_Woodworker » 05 Jan 2022, 20:29
RogerS wrote:Gosh, Mark. That's a hard call given the price. But TBH at that price, I'd try it.
Roger, I am still hesitant about buying into the expense of the ecosystem.
Can I ask where you get dominos from or do you make your own?
Thanks
Weekend_Woodworker
Postby AJB Temple » 05 Jan 2022, 21:34
Wee Woo, Roger is right about the Domino. Once you have one, you realise that they are a very fast and accurate tool. No set up at all really. Some people make dominos, but I don't bother. I buy them in big bags for the sizes I use most. I like them because they are slotted all round and compress nicely and hold glue well.
Pretty cheap. Unless you are in furniture production or something, a bag lasts a long time.
AJB Temple
Postby 9fingers » 05 Jan 2022, 21:58
Link here Mark https://www.youtube.com/watch?v=IzKHZe0YCGY
I do make my own dominos. at the end of a project I look through my offcuts and wizz them down to size on the table saw and round the corners on the router table leaving the minutest flat on the narrow sides to allow glue to escape. I keep them in sticks and trim them to suit the job as they are used.
I'm not such a huge fan of the domino machine as many seem to be, it's ok but I'm yet to be convinced enough to use it regularly and give it the cult status it is awarded by others.
Postby RogerS » 05 Jan 2022, 22:41
Thanks
Same as AJB. I buy them.
Postby Malc2098 » 06 Jan 2022, 16:51
Weekend_Woodworker wrote:Hi Stephen,
Thanks
Hi Mark,
I think the absence of the YT link might be because you're on a Mac and/or using Safari which no longer supports Flash, which this forum's software uses for linking YT videos.
I have the same issue, too. So, when I post a video, I also post the url for the YT video for those like us. I'd like to think a few more might consider us when posting vids.
Postby Weekend_Woodworker » 25 Jan 2022, 13:47
Well having procrastinated about it and balked at the price of the dF500 I have finally gone rash! I came across someone selling one second hand at a reasonable price. My dearly beloved agreed to the investment, but I don't think she bought the argument that it is a free tool as you can sell them for more than you pay for them.
All being well should pick it up tomorrow night, after which I will feel broke but have something new to play with. I suspect if I had bought the jig I was looking at originally, I would always have felt disappointed that I didn't have a Festool Domino.
Thanks for all the advice,
Mark.
P.S. Malc I think you are right, when I am on a PC I can see the videos, but when looking on the iPAD they just appear blank.
Weekend_Woodworker
Postby Andyp » 25 Jan 2022, 14:37
I've added the URL to the post and here it is again, JIC.
Postby Woodbloke » 25 Jan 2022, 15:49
I'm increasingly starting to use slots cut on the router table and a ply insert. It's actually easier that using a Domino for certain applications. This little cabinet is a case in point:
(258.47 KiB)
You can just make out the slot on the top of the side that's already been glued and plywood inserts are a lot cheaper than Domino's :D - Rob
