It is currently 28 Mar 2024, 09:23
Dalboy wrote:For someone that does flat pack you have done a great job as for the time it takes that is just a case of practice and you will be able to complete these all in one day.
Also a great job on getting them nearly all the same
Andyp wrote:Mike they are nice, very nice. How did you do the criss cross pattern?....
StevieB wrote:Very nice. As someone who has never used a lathe, and knowing your *ahem* reluctance to do so, can I ask whether you have experience of lathe work and just don't like it, or did you come at this as a complete beginner?
Mike G wrote:Dalboy wrote:For someone that does flat pack you have done a great job as for the time it takes that is just a case of practice and you will be able to complete these all in one day.
Thanks Derek. The carving takes an hour plus, so I doubt I'd ever be able to do 4 in a day.
I made a template, so getting them all the same was straightforward. I had to ease the shoulder in of one of them as one of the newel posts was a few mm undersized.
CHJ wrote:Great work Mike, excellent compliment to your staircase.
Lons wrote:.....Carving can often be done on a piece while still on the lathe......
