CSS, Buffed & Microcrystalline Wax finish.
More info for Andyp:-
Andyp wrote: Did you use gouges to hollow or a forstner bit or similar?
And when down at bottom of the bore it's helpful to use an angled cuter with good side and end rake clearance to avoid the snatching you can get with wider tool bits hitting bottom.
