It is currently 28 Mar 2024, 22:02
Andyp wrote:thanks Bob.
you don't think that I had time to clear up from my last foray into the shop do you?
It had occurred to me that I could drill on the holes into the thicker piece of mahog and then cut the slice off. A waste of wood perhaps though and I've got it earmarked for other things
9fingers wrote:Andyp wrote:thanks Bob.
Maybe cut the blank 2-3mm oversize and run through p/t with multiple fine cuts?
droogs wrote:When using the StarM augers on Hardwoods, I put a 2mm pilot where I want my hole centre and clamp a bit of scrap mdf to the rear to prevent any breakout or chipping. I'm convinced they have a much smoother entry cut into the top surface, even compared to my Fisch Forstner bits.They are also a hell of a lot easier to keep sharp as well
Malc2098 wrote:Wouldn't mind some of that apple for a guitar.
Andyp wrote:Malc2098 wrote:Wouldn't mind some of that apple for a guitar.
Drop me a PM Makc with dimensions. If I have a piece large enough it's yours. I’ll take some pictures of what I have tomorrow.
