It is currently 29 Mar 2024, 07:11
9fingers wrote:Sorted for you Stuart.
A couple of tips
1. As you upload give your photos a meaningful name so you can see which is which
2. When you get in a pickle, go to the forum view and click on Quote. This will show you the underlying code and it will be obvious why you (in this case) inserted 3 copies of the same pic and why the others were left dangling at the bottom - because they had not been inserted.
Stuart wrote:9fingers wrote:Sorted for you Stuart.
A couple of tips
But that’s whats so dammed frustrating Bob. I most definitely didn’t insert three copies of the same image and I used the place inline function using the photo numbers which is easy for me as I know where they come from.
I think I’ll resort to some text and a single photo so I can continue.
Thanks for the help.
Stuart wrote:What's interesting then Bob is how 3 copies got there when only 1 was originally inserted? Somehow my first photo appears to be replicated by however many photos I put in a post.
Users browsing this forum: Majestic-12 [Bot] and 24 guests
