It is currently 29 Mar 2024, 00:17
Trigger's Mallet
Trigger's Mallet
Postby Steve Maskery » 20 Jan 2022, 17:48
I have a nice little rubber mallet. I'm ashamed to say that I can't remember who gave it to me. If it was you, Thank You, I enjoy using it, it's great for assembling small projects.
(252.61 KiB)
There was a small split in the handle when I got it and over the last few years that split has got bigger and bigger. A couple of weeks ago, as I was assembling Stuart's casket, a chunk flew off over to the other side of the workshop. It was a shame, I like that mallet.
(211.29 KiB)
So I decided to make a new handle. But in separating the head and handle, I discovered thatt he head was also split.
(216.17 KiB)
Now superglue is excellent on rubber, but I figured that this was perishing anyway, so perhaps I should replace the head, too.
I cadged a piece of ash off Roger (thanks, Roger) and glued two pieces together to form a head blank, which was then morticed and the mortice flared out.
(198.72 KiB)
(239.18 KiB)
(221.75 KiB)
I cut the handle blank on the tablesaw, but all the tenon work was done entirely by hand. Saw and chisel.
(257.2 KiB)
I shaped the handle also by hand. Spokeshave and rasp, sandpaper.
(262.1 KiB)
(232.48 KiB)
(281.77 KiB)
I cut a couple of bog oak wedges and began assembly
(249.41 KiB)
(229.59 KiB)
This turned out to be a bit of a mistake. This bog oak gets everywhere, and later on the ash got very grubby very quickly. I should have finished all the ash before touching the bog oak. Next time, eh?
The main problem with using wood for a small mallet head is that it's not very heavy. Certainly it is lighter in feel than the rubber head. So I decided to increase its density by embedding some lead into it.
First of all I had the idea of drilling a cavity and filling it full of lead fishing weights and epoxy. I went to two fishing shops and neither had lead line weights, They were all labelled "non-toxic". I don't know what they are made of, but they certainly don't have the heft of lead. But they did have the larger weights, so I bought one of those, 12oz.
My first approach was to drill a couple of holes in a block, melt the lead and cast it. But I'd only just got going when my gas ran out. I do think that it would have worked quite well. But no gas equals no casting, so I got a big hammer and just beat the living daylights out of it until it would fit. Fun, but hard work, my arm was shaking by the end of it. The two ingots were glued in with epoxy.
(258.82 KiB)
(240.13 KiB)
Then it was a case of adding a couple of bog oak faces and cleaning up. It was at this stage I realised how beneficial it would have been to seal the ash first.
(233.3 KiB)
But it did clean up and I added a couple of leather faces. It's not hide, it was from an old sofa that one of my neighbours was trying to burn in the garden (that's how we get rid of stuff in Kirkby, we set fire to toxic material in the back garden), I think it is the leather equivalent of MDF.
(245.72 KiB)
So now I have a very nicely repaired mallet. New handle, new head, two new wedges.
(232.06 KiB)
Trigger would be proud.
Steve Maskery
Re: Trigger's Mallet
Postby kirkpoore1 » 20 Jan 2022, 19:01
Excellent, especially the work-around.
Kirk
kirkpoore1
Postby Alf » 20 Jan 2022, 19:05
Very nifty. :eusa-clap:
Alf
Postby Malc2098 » 20 Jan 2022, 19:23
Proper job!
Postby Steve Maskery » 20 Jan 2022, 19:35
And just in case there are any Martian's viewing...
Steve Maskery
Postby Andyp » 20 Jan 2022, 19:48
high praise indeed from Malc.
I think it is nice. :)
Very nice.
Postby MY63 » 21 Jan 2022, 08:24
Steve I am sure I can find some offcuts of veg tanned leather for your mallet faces if you would like some it is around 2.2mm thick.
MY63
Postby Steve Maskery » 21 Jan 2022, 09:16
That is very kind of you Michael. I'll PM you my address.
Steve Maskery
Postby MY63 » 21 Jan 2022, 10:53
Steve Maskery wrote:That is very kind of you Michael. I'll PM you my address.
I have a piece 20cm x 8cm x 2.2mm is that big enough for both ends.
MY63
Postby Steve Maskery » 21 Jan 2022, 10:55
Plenty, yes, thank you.
Steve Maskery
Postby AJB Temple » 21 Jan 2022, 11:38
Very nice. You could go into production on those.
AJB Temple
Postby Cabinetman » 21 Jan 2022, 11:53
Very nice, I wondered how you would get over the fact that it would probably mark what you were hitting, love the shape of the handle just hope it’s not a little thin just below the head, time will tell! Ian
Cabinetman
Postby Stuart » 21 Jan 2022, 12:49
That’s nice Steve. I’ve really got to get round to remaking mine, it’s rather battered!
Stuart
Postby Alf » 21 Jan 2022, 12:55
AJB Temple wrote:Very nice. You could go into production on those.
If you stick with the faux leather, Steve, you can market them as Vegan Mallets and charge a premium.
Alternatively go with the real leather, use hide glue, and MeatEaterz Mallets™ are born.
Alf
Postby Steve Maskery » 22 Jan 2022, 10:05
Alf- LOL!
Look what I've got, the photo does not do it justice.
(320.97 KiB)
It is beautiful and, even though I know nothing at all about tanning leather, I suspect that this is a high-quality, hand-crafted product.
Thank you very much indeed, Michael.
Steve Maskery
Postby MY63 » 22 Jan 2022, 19:28
You are welcome Steve pleased I could help out, It arrived quickly I only posted it at around 11.30 am yesterday. The leather is veg tanned much easier to work with than wood.
MY63
Postby Woodster » 23 Jan 2022, 13:28
Nice job on the mallet Steve.
I don’t really need one as I’ve got a couple of nice hide mallets. I’ve not thought of using leather faces before though so as I have some nice thick stuff somewhere I’ve added a leather faced mallet to my project list.
Postby Steve Maskery » 23 Jan 2022, 13:33
It's a tool, what's "need" got to do with it?
Steve Maskery
Postby Steve Maskery » 23 Jan 2022, 21:36
And the YT:
Enjoy!
Steve Maskery
Return to Projects & WIP
Users browsing this forum: Google [Bot] and 19 guests
