It is currently 28 Mar 2024, 15:54
Table
Table
Postby MY63 » 22 Jan 2022, 19:59
Firstly I need to thank someone, I was reading a post last week where someone mentioned buying a table from gumtree for parts. As my daughter is moving soon and she wanted a table "Bingo" she found one just down the road. It is a John Lewis table 20 years old it cost £2000 when new they were asking £25.
Clearly we bought it and collected it.
The top as you can see is worn no worse than my neighbours restaraunt tables. The picture below is one of the rails with the only marking I can see. It looks to be an oak base they are dovetailed into the side pieces. I think the top is oak veneer the underneath has a fine grain with a red tone it looks like sapelle.
Image2022-01-22_06-43-25 by my0771, on Flickr
Image2022-01-22_06-29-25 by my0771, on Flickr
It has been a family table for a long time and has some felt tip marks and scratches along with some heavy wear.
Some of the surface that has worn is significantly lower than the unworn areas can I build up layers of varinsh I plan to use the water based floor varnish as reccomended by Bob. Or should I sand the whole thing and varnish the whole thing??
MY63
Re: Table
Postby Phil » 23 Jan 2022, 07:08
Nice buy Michael. Good price.
Strip off all the old finish and then start off from scratch, then a couple of coats of PU to take a lot of wear.
Nice clear matt finish to show off the wood.
Re: Table
Postby AndyT » 23 Jan 2022, 09:53
Bargain!
The top is definitely veneered, as you can see from the repeating grain pattern.
Can you see how thin the veneer is, maybe from one of the internal straight edges, if they are unlipped? Clearly, you don't want to sand through it. A slightly unflat surface doesn't stop it working as a table.
AndyT
Re: Table
Postby TrimTheKing » 23 Jan 2022, 11:37
I’m a bit confused, it seems to have a rounded edge down which the grain pattern flows. How can it be veneered in that case…?
Re: Table
Postby AndyT » 23 Jan 2022, 11:43
TrimTheKing wrote:I’m a bit confused, it seems to have a rounded edge down which the grain pattern flows. How can it be veneered in that case…?
:oops: Maybe it's bookmatched boards, not veneer! :oops:
I need a bigger screen or better eyes!
AndyT
Re: Table
Postby Woodbloke » 23 Jan 2022, 13:49
The grain pattern is far too similar to be solid timber, so my guess is that it's veneered, with a very wide lipping applied to the substrate to accommodate the curvature of the top - Rob
Re: Table
Postby TrimTheKing » 23 Jan 2022, 14:05
I’m not buying it Rob. Look at this, the grain is continuous from the main table down the curve…
Re: Table
Postby Woodbloke » 23 Jan 2022, 15:22
Odd though Mark? :eusa-think: Look at the grain pattern in the boards and they're virtually identical; I do agree though that the end grain pattern as shown in your pic above is continuous - Rob
Re: Table
Postby TrimTheKing » 23 Jan 2022, 15:37
Yep agreed, just unusually good board selection/grain matching for a production piece maybe.
Re: Table
Postby MY63 » 23 Jan 2022, 18:19
I have taken some extra pictures of the underneath of the table. I can lift the leaf but I would rather not as each one is very heavy.
The grain does indeed continue over the curved edges if there is a solid edge I cannot see the join.
Image2022-01-23_04-29-25 by my0771, on Flickr
Image2022-01-23_04-35-15 by my0771, on Flickr
Image2022-01-23_04-35-48 by my0771, on Flickr
The last picture shows the only joint I could find just below the dark line.
MY63
Re: Table
Postby AndyT » 23 Jan 2022, 18:26
I think there is no risk at all of sanding through that nice solid top!
An even better bargain.
AndyT
Return to Projects & WIP
Users browsing this forum: GaryR and 13 guests
