It is currently 29 Mar 2024, 09:43
AJB Temple wrote:Quality work. I like the floating cupboard concept. The whole base has a Japanese or oriental feel to me.
Woodbloke wrote:A question about the finish Peter; what did you use on the cabinet? It loos like it could be some type of oil/wax based finish on the cherry? - Rob
AJB Temple wrote:Thanks for the explanation Peter.
The inlay technique interests me as I have done quite a few (around 170) guitar neck inlays quite a few years ago, and it was always very time consuming as it was a hand tools job for me apart from a bit of light roughing out with a router.
Yours loom extremely crisp, but I am not familiar with the tool you refer to.
I would like to get back to that kind of skilled work.
KR, Adrian
thetyreman wrote:amazing work peter! very neat and precise, a true heirloom quality piece, that's something to be proud of.
Peter F. wrote:Woodbloke wrote:A question about the finish Peter; what did you use on the cabinet? It looks like it could be some type of oil/wax based finish on the cherry? - Rob
That's right, Rob. I used Maloof's poly/oil finish. I used to sand to 1000 grit and put 6-8 coats of finish on. But I decided I didn't like the shiny, burnished look that the wood acquired. So instead, I sanded this piece to 320, and did only two coats of finish. It has a lovely texture to the hand, and a duller sheen, which I like. I'll probably stick with it.
Users browsing this forum: wallace and 16 guests
