It is currently 28 Mar 2024, 18:14
Image posting for Mac users
Postby Andyp » 01 Dec 2021, 15:46
Guys and Gals,
we have developed a method of overwriting the exif orientation data on images that appear correctly on the Mac but rotate when uploaded to WH2 on a post.
The Macs come with a built in tool called Automator. This can be used to perform any number and type of repetitive tasks.
Using Automator we have created a Workflow that rotates an image 180 degrees twice.
Once installed it is a simple as this to run.
or
https://www.youtube.com/watch?v=mVP_lDaEPPM
you wont notice any change to the images on the iMac as I said above the idea is to run it on those images that appear correct on the Mac but rotate when uploaded to WH2.
If anyone is interesting in this solution please drop me a PM with an email address.
This by no means will prevent us from updating the forum software but it may help some Mac users in the meantime.
Re: Image posting for Mac users
Postby TrimTheKing » 01 Dec 2021, 16:58
Excellent work Andy, thanks!
:obscene-drinkingcheers:
Postby Andyp » 01 Dec 2021, 17:40
TrimTheKing wrote:Excellent work Andy, thanks!
And Roger.
Dunno why I didn't try it earlier.
Postby Stuart » 01 Dec 2021, 21:43
Andy’s recent tip to me of simply rotating the image, save it, and then rotate back before posting also seems to work. Didn’t take long in practice either although I suspect your process is easier.
I’m still white sticking my way around the macs file structure!
Stuart
Postby 9fingers » 02 Dec 2021, 11:46
Isn't just about the worst thing about changing operating systems?
After several years of finding my way round the way iOS does things, trying to find my way around wifes Android OS is a nightmare.
Would be so much easier if IT came with a written guide eh?
Postby Andyp » 02 Dec 2021, 11:53
Stuart wrote:Andy’s recent tip to me of simply rotating the image, save it, and then rotate back before posting also seems to work. Didn’t take long in practice either although I suspect your process is easier.
whenever you are ready Stuart PM me your email and I'll send you the workflow. It does exactly what you are doing but at a single click or two of the mouse.
I've have never felt the need to understand the file structure of the Mac. I am sure there is a word for someone who drives a car without understanding exactly how it works. That's me and computers. I can make 'em work. I can use google to help me find out how to do stuff, like the automator workflow for example. I have too many other things to try and make sense of in life to bother about how a computer works.
Hope that does not sound flippant and is not meant to be a dig at those that do understand this stuff. I am truly in awe at the depth of knowledge about so many things around here.
Postby RogerS » 02 Dec 2021, 11:56
One thing that I found confusing on the Mac when Catalina arrived was the virtual separation of the hard drive into something called Macintosh HD - data.
Postby Stuart » 02 Dec 2021, 14:34
Andyp wrote:quote="Stuart"]
Doesn’t sound flippant at all Andy.
Don’t get me wrong, I’m not trying to understand the ins and outs of the structure simply to understand where stuff is so I can access it.
For example, attaching photos to the WIP means I need to know where they are. I managed simply becasue they taken on a phone and airdropped And could be picked up from ‘recent’.
Trying to find the photo directory (as in windows) to select individual or groups of photos is prooving a bit elusive!
I don’t want to turn the forum into my mac woes so I’ll leave it here.
Stuart
Postby TrimTheKing » 02 Dec 2021, 14:38
Stuart wrote:Trying to find the photo directory (as in windows) to select individual or groups of photos is prooving a bit elusive!
Photo's are stored in a database file not in a directory, so if you need individual pics you export them from 'Photos' app into a directory. There are ways to open the DB, but you really don't want to start doing that as it has the potential to corrupt the DB and you risk all your photos then.
It's a different way of working that's for sure.
Postby Andyp » 02 Dec 2021, 14:41
Stuart, conversations flow and if you are having problems posting images we are here to help.
Unfortunately I do not use airdrop so I do not know where it dumps them but I hope someone will be along soon .
Postby RogerS » 02 Dec 2021, 14:44
:( My iPhone seems to have stopped automatically uploading photos to the cloud so that I can easily ccess them from my desktop.
Postby AJB Temple » 02 Dec 2021, 18:46
Iphone needs to have box ticked in settings for cloud sync for Photos etc.
AJB Temple
Postby Andy Kev. » 03 Dec 2021, 10:08
I understood one word in the first sentence: “Mac” and that’s only cos I own one. I’ll sit down with this tonight and read it very slooowly.
Andy Kev.
Postby Woodster » 03 Dec 2021, 11:39
Andyp wrote:Unfortunately I do not use airdrop so I do not know where it dumps them but I hope someone will be along soon .
Pictures airdropped to an iOS device go to Photos. On a Mac they go to Downloads.
https://www.imobie.com/support/where-do ... tos-go.htm
If you Airdrop other files like say a PDF document to an iOS device it asks where to store it.
I usually choose “Files” for something like a PDF.
Users browsing this forum: Bing [Bot] and 19 guests
