It is currently 28 Mar 2024, 21:01
air fed masks
air fed masks
Postby wallace » 25 Jan 2022, 09:04
You all know I like to mess about with the odd bit of paint. I have always been a stickler for ppe and use a powered respirator whenever in my shop. When spraying I use a sundstrom rubber mask with appropriate filter. I have grown a decent amount of face fluff in the last 6months and understand this can interfere with good sealing and so protection being compromised.
Is anyone clued up on air fed masks. I found a mask and 3 stage filter on ebay, but it looks a bit janky to me.
https://www.ebay.co.uk/itm/185002778037?
There is also a devilbus 3 stage filter which looks the business
My compressor is a good 15years old and very well used.
wallace
Re: air fed masks
Postby MY63 » 25 Jan 2022, 10:30
Sorry Wallace having re read your post I dont think my post answered your question.
MY63
Re: air fed masks
Postby wallace » 25 Jan 2022, 11:25
That one I linked to does look very dodgy. I think I would have problems with sealing even if I used a full faced rubber mask.
I think I will look into the updated version of my 3m versiflo, I think you can get filters for use with paints
wallace
Re: air fed masks
Postby Lurker » 25 Jan 2022, 11:31
Don’t even think about an air fed mask unless you have the correct air supply and for that you will pay thousands.
I assume that your current set up is air sucked over a filter by an independent pump. Ie positive air flow, for those a face seal isn’t necessary or indeed helpful.
Then all that you need to worry about is that you are using the correct filters and that the positive air flow is up to spec.
Lurker
Re: air fed masks
Postby Lurker » 25 Jan 2022, 11:37
wallace wrote:That one I linked to does look very dodgy. I think I would have problems with sealing even if I used a full faced rubber mask.
That’s the best system, 3 m website will steer you to the best filters configurations. It’s all down to the paint types you use.
Lurker
Re: air fed masks
Postby droogs » 25 Jan 2022, 11:47
If you have facial hair around you chin longer than 1.5mm it will prevent any western style respirator (those that seal around the jaw and hair line) from making a proper protective seal. You need a schlaeger (soviet) style full head mask that seals around the neck like below
https://www.google.com/url?sa=i&url=htt ... AdAAAAABAD
I'm not aware of any commercial types of mask that use this system of sealing. It's either shave or be a prepper lol
droogs
Re: air fed masks
Postby wallace » 25 Jan 2022, 12:47
Of coarse 3M dont offer the filters I need on my fan unit.
wallace
Re: air fed masks
Postby Lurker » 25 Jan 2022, 14:05
wallace wrote:Of coarse 3M dont offer the filters I need on my fan unit.
What do you have at the present?
Lurker
Re: air fed masks
Postby wallace » 25 Jan 2022, 16:39
I have the 300 series https://www.ebay.co.uk/itm/255266473491?
I found someone selling a 600 series fan unit for £125 appropriate filters for spraying are available so have ordered one.
wallace
Re: air fed masks
Postby Lurker » 25 Jan 2022, 17:02
Result then?
Lurker
Re: air fed masks
Postby wallace » 25 Jan 2022, 17:47
Lurker wrote:Result then?
Yeah peace of mind for £170, I might get a hood as well
wallace
Re: air fed masks
Postby wallace » 04 Feb 2022, 17:15
My new filter unit arrived, I had to buy a charger and the appropriate filter cartridge, very pleased with the result. I thought 3m had changed the units just to screw more money out of people. The paint filters weren't available for my old filter unit. The new unit is much bigger and has speed control.
I feel sorry for companys that have to supply this stuff to employees, this little lot would of cost £1k from a proper supplier.
I suppose their might be a glut of ppe being flogged off cheap considering the government wrote of a couple of billion pounds of it recently
wallace
