It is currently 29 Mar 2024, 07:18
Robert wrote:Oh and YouTube is another problem - there are so many 'how to's' based on old version software and the current version seem greatly changed so you have to find the equivalent command and where it is not just follow the instructions.
DaveL wrote:You need to of made the part, I think is called a component and then when it's selected there should be little square handles. If you find the right one you should be able to drag it and change the length.
Other way that might work is to put a dimension on the length, then select the size shown and over type with the required new size.
Neither of these ideas carry any sort of guarantee to work or not break your drawing.
DaveL wrote:Hi Dave,
I have only used F360 as a means of generating G code for my CNC.
The only full plans I have drawn are for the table a few years ago produced in SketchUp, referring back to you tutorial I got from Fine Woodworking.
9fingers wrote:
Yes I know the bottom is missing.
Andyp wrote:Is it me or is the perspective a little out too? The far end looks a little odd.
Hats off to you learn something new BTW. Last time I used I think sketchup it took me longer to draw than to make the the poject!
