I'll start with storage...
This is a rack for Narex carving chisels - the printer makes it easy to make tapered square holes:
On the left of that image is holder for two taper shank adaptors for a hand brace (with custom shaped holes to match the taper):
There are even more of this sort of thing in the next two photos (chisel racks, drill bit racks and holders for two planes):
This:
is a very simple thing that I made to mount under my bench so I could slide a short bit of guide rail under there and have it close at hand:
This is a holder for a small drill:
and a holder for lots of bench dogs (some of which were also 3D printed) and some belt clip things:
This is a holder for t-handle hex-keys, with hexagonal holes so the keys don't rotate and get in each others' way:
This is a simple rack for holding Forstner bits (with holes for all the readily available sizes, many of which I don't own):
This rack (with magnets embedded into the 3D printed object) clips onto the back of my home-made filing machine and gives some storage space for the files etc:
and finally (for storage stuff), this is a complete custom drawer unit for threading taps and dies with dedicated spaces for taper, second, bottoming, serial, spiral flute, spiral point and fluteless taps:
example drawer:
