It is currently 28 Mar 2024, 19:34
9fingers wrote:I did not bother to vent my gable ends as there is crossflow ventilation at soffit level behind the gutter/fascia.
John Brown wrote:While I'm searching in vain for cheap PIR for my roof, I wondered what the downside might be to using the surplus batts of rockwool I have left over - apart from the obvious problem of keeping it im place and getting fibres in my hair and eyes...
RogerS wrote:John Brown wrote:While I'm searching in vain for cheap PIR for my roof, I wondered what the downside might be to using the surplus batts of rockwool I have left over - apart from the obvious problem of keeping it im place and getting fibres in my hair and eyes...
Are Seconds and Co still going ?
John Brown wrote:Well that's you sorted then...
Not much help to me. I suppose I could buy a few lottery tickets, see if I can get lucky too.
9fingers wrote:I think you will need a different slab design/DPC arrangement to take it from the shed design to more of a habitable space that will stay adequately dry with less "open to the air" ventilation. You don't want an exposed edge of the floor slab with the ability wick damp into the inner floor.
Mike might have a different solution but I'd be thinking of a strip foundation maybe with steel rebar, dwarf walls with DPC 150mm above ground. An internal insulated slab floor with DPM under tucked into the DPC all round.
greeno wrote:Thanks Mike, no rush. The slab will probably be in a couple of months. If there's no simple alternative then we might stick with the original design.
Out of interest, what is the thinking behind the 50mm?
Any thoughts on vapour barrier + plasterboard or osb and plasterboard?
