Hi All
I've gone about this the wrong way. I should have been more organised and checked this first. I've purchased a 10" Sedgwick planer thicknesser. It weighs around 264kg.
My workshop floor is suspended. Joists at 400mm centres and max span is 1.4m as they are supported ends and centre on a coarse of bricks, DPC, timber sole plate. The joists are 47x125mm C24. Flooring is 22mm glued moisture resistant chipboard. I also ensured all T&G joints landed on a joist, none are flying.
My plan was that the planer would be stored at edge of workshop and then pushed out for use.
Does this sound ok? I thought it was but now I am doubting myself and am in a pickle.
Thanks in advance of help
Sent from my ONEPLUS A6003 using Tapatalk
