will1983
I bought a baily no6 off eBay ages ago and decided to give it a bit of a clean up at the weekend. However it appears that the holes in the frog don't line up with the threaded holes in the bed of the plane.
The holes are the same distance apart but appear to be to far back in the bed by about 5mm. This has the impact that the blade will not project through the mouth, it clashes with the rear of the mouth.
Does anyone know what's going on there? Obviously the frog isn't the original and has been replaced with a similar but not an exact component at some point.
Apart from this the rest of the plane appears to be in good condition. I would like to start using it so if someone knows where I can get a new frog that will fit please enlighten me.
Thanks
Will
P.s. Copied this over from the UKW forum.
Thanks
Will
