Redundant Cherry kitchen cabinet doors
Tiverton
I have some leftover cherry doors from the old kitchen cabinets from when we moved here 16 years ago. So what could I do with them?
With a bit of laminating and imagination, I came up with this. :)
Curious Malc, how long did the machine take to finish the clock?
It wasn't quick, I can tell you that, because I had a few programming issues down to me that I had to resolve. The text took the longest, I think the circular text was over half an hour. the accent cycle and the outer profile were minutes. the fives took a while, too.
I built my machine, mostly from a kit, so I am very conservative with my feeds and speeds, so it's lucky I'm retired and don't use it for a business.:)
For those whose brains might have gone squiffy with fives all round the clock, this one's for you.
I'm still having to reduce their size.
Preview said they were 6.4mb together.
Can you see how the timber has cupped? I zeroed the Z axis some where near the nine, and that turned out how I wanted it.
But the timber cupped on the machine bed, because it was on a few days while I had to sort a configuration issue. I think the morning sun got to it. So the north/south 12/6 cupped up, causing a deeper cut.
Could you program in a reset of the Z axis before every number to avoid this issue in the future?
Creating 12 individual tool paths with 12 different surface zeros would work but would be quite time consuming.
But I've recently bought a trigger edge finder which also triggers on the Z axis. The control software I use has a surface mapping function that I've not yet learned how to use, but would have avoided the different depths of cut.
